MK4 Nextruder makes squeaking noise while printing
[Solved] MK4 Nextruder makes squeaking noise while printing
Henry
(@henry-8)
Hey all,
Two days ago my 2-month old MK4 started squeaking; first it began only while moving along the X-Axis then Yesterday(May 31st) ti started for both X & Y.  I print with PETG and PLA and it does it for both filament types. I am currently using the eSun brand or filament
Video: https://drive.google.com/file/d/1WbXOmQhF8VZlEtEBkk-rV7AcfQ9MfBqg/view?usp=sharing
What I have tried:
1. Raising the Z while printing => That did not fix the issue
2. Loosening the Idler nuts => That did not fix the issue
3. Tightening the Idler nuts => That did not fix the issue but it got past mostly through the first layer without squeaking.
4. Check if any parts a rubbing somewhere => No joy there either
5: I saw the post titled: `Horrible squeaking developed after 6 days of perfectly silent printing` and thought I needed to print new parts. I inspected those parts and the look well-printed. Better than most of the other parts  😆. Since my printer is only two month old and the parts are well printed I don't think that is my issue.
Can someone help me out here?
Napsal : 01/06/2024 7:31 am
Henry
(@henry-8)
RE: MK4 Nextruder makes squeaking noise while printing
Quick update: I switched to some old Polymaker PolyPlus PLA (Over 2 years old) and successfully printed a 3h 27min print with no squeaking 🤔 . I think this eSun brand should not be my goTo. I will try another print and resolve this if I still get no squeaking
Napsal : 01/06/2024 2:57 pm
