					                		Blobs and scorch marks on otherwise perfect first few layers - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/blobs-and-scorch-marks-on-otherwise-perfect-first-few-layers/</link>
                <lastBuildDate>Wed, 17 Jun 2026 16:24:16 +0000</lastBuildDate>
                        <title>RE: Blobs and scorch marks on otherwise perfect first few layers</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/blobs-and-scorch-marks-on-otherwise-perfect-first-few-layers/#post-752449</link>
                        <pubDate>Mon, 02 Jun 2025 21:30:23 +0000</pubDate>
                        <description><![CDATA[When you assembled your nozzle assembly with the V6 adapter and a regular V6 nozzle, did you hot-torque it like you would on a regular V6 hot-end? If not, that might have been the root cause...]]></description>
                        <content:encoded><![CDATA[<p>When you assembled your nozzle assembly with the V6 adapter and a regular V6 nozzle, did you hot-torque it like you would on a regular V6 hot-end? If not, that might have been the root cause of your issue (or might be a future issue).</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Sembazuru</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/blobs-and-scorch-marks-on-otherwise-perfect-first-few-layers/#post-752449</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/blobs-and-scorch-marks-on-otherwise-perfect-first-few-layers/#post-751250</link>
                        <pubDate>Mon, 26 May 2025 00:02:05 +0000</pubDate>
                        <description><![CDATA[I figured it out. I had completely forgotten that I had installed a V6 nozzle adaptor on this unit about a month ago. I guess I didn&#039;t tighten it enough against itself, and it had been leaki...]]></description>
                        <content:encoded><![CDATA[<p>I figured it out. I had completely forgotten that I had installed a V6 nozzle adaptor on this unit about a month ago. I guess I didn't tighten it enough against itself, and it had been leaking inside the heat block :( Swapped for a new one, and I was off to the races.</p><p> </p><p>thx!</p><p> </p><p>AJ</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>ajemutt</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/blobs-and-scorch-marks-on-otherwise-perfect-first-few-layers/#post-751250</guid>
                        <title>Blobs and scorch marks on otherwise perfect first few layers</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/blobs-and-scorch-marks-on-otherwise-perfect-first-few-layers/#post-751231</link>
                        <pubDate>Sun, 25 May 2025 20:37:27 +0000</pubDate>
                        <description><![CDATA[Hi there, I&#039;m running a Mk4 with the firmware as of 5.11.25. Prusament transparent blue PETG270 deg nozzle90 deg bed.2 layer heightWell dried filament100% infill (I&#039;m trying to make sure the...]]></description>
                        <content:encoded><![CDATA[<p>Hi there,</p><p> </p><p>I'm running a Mk4 with the firmware as of 5.11.25. </p><p>Prusament transparent blue PETG</p><p>270 deg nozzle</p><p>90 deg bed</p><p>.2 layer height</p><p>Well dried filament</p><p>100% infill (I'm trying to make sure the layers stick really well)</p><p>The print before this one failed due to late layer offset due to (I suspect) filament blobs around the nozzle. I cleaned those up, and also looked inside the extruder gears to make sure nothing was amiss inside there. Didn't see anything, so cleaned the bed,  and started a new print. </p><p>About 1/3 of the way through the 2nd layer, I noticed 1 blob, and 2 scorch marks on the print itself (see attached photo). I searched around a bit to see if I could see any similar reports, but nothing came up immediately.</p><p>Can anyone fill me in on what might be causing this?</p><p> </p><p>thx!</p><p> </p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/159f53e8-img_8223-scaled.jpg"><img class="alignnone size-medium wp-image-177235" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/05/159f53e8-img_8223-600x500.jpg" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk4-assembly-and-first-prints-troubleshooting/blobs-and-scorch-marks-on-otherwise-perfect-first-few-layers/#post-751231</guid>
