USB HUB NOT WORKING
I order to reduce/eliminate wear and tear on the USB connector in my 3.9S I have been trying to connect a USB hub. The idea is to use the hub connections instead of the original. I have tried two separate hubs, and the printer will not recognize a USB placed into a hub connection when it will when the USB is directly connected to the printer.
Suggestions/recommendations/solution??
Dean
Publié : 16/03/2025 4:01 pm
