					                		Filament load presets - Hardware, firmware and software help                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/</link>
                <lastBuildDate>Tue, 12 May 2026 00:39:04 +0000</lastBuildDate>
                        <title>RE: Filament load presets</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-755267</link>
                        <pubDate>Tue, 24 Jun 2025 03:18:44 +0000</pubDate>
                        <description><![CDATA[Posted by: @codymammenga I am wondering if there is a way to add more filament presets in the menu on the machine?  I use PCTG and I also use another higher temp PETG and I have to manually ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="570098" data-postid="736012" data-mention="codymammenga"><div class="wpforo-post-quote-author"><strong> Posted by: @codymammenga </strong></div><p>I am wondering if there is a way to add more filament presets in the menu on the machine?  I use PCTG and I also use another higher temp PETG and I have to manually go in and heat up the hot end then select PETG and then when I slice it and go to print they always tell me there is a different filament loaded would you like to still continue?  I looked in the menus and tried searching here but couldn't find anything to help me create a couple filament presets or adjust the factory presets?</p></blockquote><p>Unfortunately, most machines don’t allow custom filament presets directly on the printer. You can try editing the material profiles in your slicer and name them accordingly—then match those settings manually on the printer.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>Fortust</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-755267</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-736157</link>
                        <pubDate>Tue, 11 Feb 2025 14:24:56 +0000</pubDate>
                        <description><![CDATA[Are you talking in prusa slicer? I am talking about on the machine itself.  I didn’t see a floppy disc on the filament menu on the machine itself.  I am wanting to change those as there is n...]]></description>
                        <content:encoded><![CDATA[<p>Are you talking in prusa slicer? I am talking about on the machine itself.  I didn’t see a floppy disc on the filament menu on the machine itself.  I am wanting to change those as there is no PCTG and my PETG needs to be 250 to load on the hot end and at the factory 230 I get extruder clicking </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>codymammenga</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-736157</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-736014</link>
                        <pubDate>Mon, 10 Feb 2025 18:55:28 +0000</pubDate>
                        <description><![CDATA[If you go to the Filaments tab  at the top and click the little Floppy Disk symbol next to Preset name drop down, it will let you save new Filament Presets under a new name.]]></description>
                        <content:encoded><![CDATA[<p>If you go to the Filaments tab  at the top and click the little Floppy Disk symbol next to Preset name drop down, it will let you save new Filament Presets under a new name.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/">Hardware, firmware and software help</category>                        <dc:creator>3Delight</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-736014</guid>
                        <title>Filament load presets</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-736012</link>
                        <pubDate>Mon, 10 Feb 2025 18:49:12 +0000</pubDate>
                        <description><![CDATA[I am wondering if there is a way to add more filament presets in the menu on the machine?  I use PCTG and I also use another higher temp PETG and I have to manually go in and heat up the hot...]]></description>
                        <content:encoded><![CDATA[<p>I am wondering if there is a way to add more filament presets in the menu on the machine?  I use PCTG and I also use another higher temp PETG and I have to manually go in and heat up the hot end then select PETG and then when I slice it and go to print they always tell me there is a different filament loaded would you like to still continue?  I looked in the menus and tried searching here but couldn't find anything to help me create a couple filament presets or adjust the factory presets?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-9s-hardware-firmware-and-software-help/filament-load-presets/#post-736012</guid>
