Areas without material in the print
Jussi
(@jussi-2)
Hi Community!
Any idea what could cause the lack of material beside the oval holes? Feels that the nozzle does not go far enough or there is lack of extrusion. I'm using the default profile and using PETG. 0,2mm layer height and 0,4mm nozzle. I have printed this print earlier as well (several months ago) with default settings, but now the empty spots appeared. I have created the gcode with the latest settings. I feel that the only real change is the updates in the slicer software and printer firmware. I use PrusaSlicer. Can arachne create this? The successfull prints were before that.
Opublikowany : 30/10/2024 12:21 pm
1 ludzie polubili
Jussi
(@jussi-2)
RE: Areas without material in the print
It is not arachne. Tested that and it gives the same result.
Opublikowany : 06/11/2024 6:37 am
1 ludzie polubili
