3x MK3s+ and 1 print different
HI!
I have 3 MK3S+ and with one printer i have a problem to print 45°.
I use the same GCode and petg material. The firmware is the same.
I changed fan, thermistor, thermal paste and so on...
I did the temperature calibration.
I print the same part on other position on heatbed, but same result.
I haven't replaced the entire hotend yet; first, I would like to ask you
Does anyone else have any idea what the problem could be?
RE: 3x MK3s+ and 1 print different
What was the failure?
was it lack of adhesion?
If so,
I find that washing the build plate with hot water and dish soap, works wonders
No, the 45-degree overhangs were not printed cleanly. They are sagging.
