Just upgraded to i3mk3.5S with MMU3 and old gcode I used to run without MMU3 says isn't fully compatible
Dschiri1
(@dschiri1)
Well I upgraded from a i3mk3s to a i3mk3.5s. Then I just upgraded to i3mk3.5s with MMU3. I have some old i3mk3s gcode (VBS 3d face mask small mag_0.15mm_Silk_PLA_MK3S_1h48m - R2.gcode). I could run this g-code when it was upgraded to i3mk3.5s. But now it says "The G-code isn't fully compatible". I've lost my hard drive that had the model and stl files, so it will be very hard to get it back ie 1,500.00 USD. What do I need to do in order to get it to run on i3mk3.5s with MMU3?
DS
Napsal : 02/06/2025 12:38 am
RE: Just upgraded to i3mk3.5S with MMU3 and old gcode I used to run without MMU3 says isn't fully compatible
See my response here https://forum.prusa3d.com/forum/postid/752323/
Napsal : 02/06/2025 11:08 am
