64 GB Samsung USB Stick, not enough space when uploading via prusalink.
deepblue4200
(@deepblue4200)
I replaced the default Prusa USB stick with a new Samsung USB 64Gb Stick.
I formatted it with the HP USB Format Tool to Fat32 with the full 64GB.
The printer seems to detect it without problem.
But when I try to push a file via Prusalink directly from the slicer. I get the error:
Der Upload ist fehlgeschlagen. Es wurde kein geeigneter Speicherplatz unter 10.20.9. 109 gefunden
Upload failed. No suitable storage location was found under 10.20.9. 109
Thank you in advance!
Best Answer by K7ZPJ:
Try formating your USB stick with one of the formating tools that is listed in the Prusa help article on USB memory.
Here is the link to the help article: https://help.prusa3d.com/article/sd-cards-and-usb-drives_112291
I have sucessfuly used Rufus and  FAT32 format to format  64+ GB USB drives to work with my printers.
Posted : 07/02/2025 4:16 pm
K7ZPJ
(@k7zpj)
RE: 64 GB Samsung USB Stick, not enough space when uploading via prusalink.
Posted : 07/02/2025 6:17 pm
deepblue4200
(@deepblue4200)
Rufus did the trick. Thank you!
Posted : 08/02/2025 2:01 pm
