					                		3.5s+ upgrade, can&#039;t get x axis calibration to complete successfully - Assembly and first prints troubleshooting                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/3-5s-upgrade-cant-get-x-axis-calibration-to-complete-successfully/</link>
                <lastBuildDate>Fri, 10 Apr 2026 23:39:29 +0000</lastBuildDate>
                        <title>RE: 3.5s+ upgrade, can&#039;t get x axis calibration to complete successfully</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/3-5s-upgrade-cant-get-x-axis-calibration-to-complete-successfully/#post-780714</link>
                        <pubDate>Wed, 04 Feb 2026 01:17:58 +0000</pubDate>
                        <description><![CDATA[OK, I think I found my issue.  I got a successful X Axis check.I changed the X stepper pulley and slid it out, away from the stepper motor, just a smidge.  The only thing I changed to get th...]]></description>
                        <content:encoded><![CDATA[<p>OK, I think I found my issue.  I got a successful X Axis check.<br /><br />I changed the X stepper pulley and slid it out, away from the stepper motor, just a smidge.  The only thing I changed to get this to pass a test.  The only thing I didn't change prior to that.  Basically I tried to make sure it was tracking true with the belt.</p><p> </p><p>Hope this helps someone.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Looper</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/3-5s-upgrade-cant-get-x-axis-calibration-to-complete-successfully/#post-780714</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/3-5s-upgrade-cant-get-x-axis-calibration-to-complete-successfully/#post-780697</link>
                        <pubDate>Tue, 03 Feb 2026 21:10:27 +0000</pubDate>
                        <description><![CDATA[Posted by: @pete-6 I know this problem is posted somewhere else in these forums,  but I&#039;m having the dreaded x axis calibration failure (with no diagnostic message to help) after upgrading m...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="605713" data-postid="778802" data-mention="pete-6"><div class="wpforo-post-quote-author"><strong> Posted by: @pete-6 </strong></div><p>I know this problem is posted somewhere else in these forums,  but I'm having the dreaded x axis calibration failure (with no diagnostic message to help) after upgrading my 3s+ to a mk3.5s+, and changing out the pinda for the superpinda. I've literally spent hours on this at this point.   here's what I've checked and tried: </p><p>* verified that zip ties are not interfering</p><p>* checked for smooth operation across the axis.  rods are clean and bearings seem OK</p><p>* tried with belt "a little tight", "a little loose", "too tight", "too loose" and perfect,  all have made no difference - any value between 58 and140hz onthe belt tuner </p><p>* removed screws in back end of hot end fan,  they may have been contacting z axis screws (no change) </p><p>* held heat bed cable bundle aside during calibration to make sure it's not interfering</p><p>Sometimes the calibration will bounce off the left side many (&gt;20) times, other times only a few,  but I always get a fail . </p></blockquote><p>I am seeing the same thing here. </p><p>Installed new 3.5s+ kit, and heat bed, on a MK3 that had been updated to a MK3S+.  The MK3s+ had been printing fine and had passed all calibration test a week prior to this upgrade when I upgraded it from an MK3.  <br /><br />I have completely disassembled the the X/Z rods, verified bearings are in the right clock orientation, re-lubed bearings with Prusa Lube. Assembled everything and tried it with the belt too loose, too tight and just right.  no improvements.  still a red X on the the X axis.  Nothing is hitting everything moved freely. <br /><br />I have looked over the Crash docs and verified everything on that list.  Anyone with any ideas?<br /><br />The original MK3 had very few hours on it as I never used it much, maybe two days of print time.  I bought it new to use with an MMU1 that got upgraded to an MMU2. It then sat in a corn for a few years and I just dug it out to upgrade it and the MMU2 to a MMU3.  Was hoping to gain some speed with the MK3.5S+ upgrade.</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/3-5s-upgrade-cant-get-x-axis-calibration-to-complete-successfully/#post-780697</guid>
                        <title>3.5s+ upgrade, can&#039;t get x axis calibration to complete successfully</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/3-5s-upgrade-cant-get-x-axis-calibration-to-complete-successfully/#post-778802</link>
                        <pubDate>Mon, 19 Jan 2026 20:13:20 +0000</pubDate>
                        <description><![CDATA[I know this problem is posted somewhere else in these forums,  but I&#039;m having the dreaded x axis calibration failure (with no diagnostic message to help) after upgrading my 3s+ to a mk3.5s+,...]]></description>
                        <content:encoded><![CDATA[<p>I know this problem is posted somewhere else in these forums,  but I'm having the dreaded x axis calibration failure (with no diagnostic message to help) after upgrading my 3s+ to a mk3.5s+, and changing out the pinda for the superpinda. I've literally spent hours on this at this point.   here's what I've checked and tried: </p><p>* verified that zip ties are not interfering</p><p>* checked for smooth operation across the axis.  rods are clean and bearings seem OK</p><p>* tried with belt "a little tight", "a little loose", "too tight", "too loose" and perfect,  all have made no difference - any value between 58 and140hz onthe belt tuner </p><p>* removed screws in back end of hot end fan,  they may have been contacting z axis screws (no change) </p><p>* held heat bed cable bundle aside during calibration to make sure it's not interfering</p><p>Sometimes the calibration will bounce off the left side many (&gt;20) times, other times only a few,  but I always get a fail . </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/">Assembly and first prints troubleshooting</category>                        <dc:creator>Pete</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mk3-5s-assembly-and-first-prints-troubleshooting/3-5s-upgrade-cant-get-x-axis-calibration-to-complete-successfully/#post-778802</guid>
