        Z axis crash with vertical profile
Z axis crash with vertical profile.
Can I adjust it not to crash?
                            Opublikowany : 14/01/2022 2:31 am
                            Opublikowany : 14/01/2022 2:33 am
                    RE: Z axis crash with vertical profile
I would contact support, Prusa Support. I'm pretty sure that's not supposed to happen.
The Filament Whisperer
                            Opublikowany : 14/01/2022 2:43 am
                    1 ludzie polubili
						Topic starter
 answered:
Thank you, I already contacted prusa and get fix. Problem is after get fix at the local shop. They move a x-axis smooth rod to adjust a belt. But after around 10 print smooth rod crash with z profile.
To fix untighten 4 screw Infront the rod, lower tension of belt at end of x axis, move smooth rod and screw all 4 screw to lock the rod. Adjust tension the belt(with tension meter for mini).
Done, nightmare gone. Thanks to quick response of prusa.
                            Opublikowany : 15/01/2022 2:43 am
                    1 ludzie polubili
