					                		X Crash Detected error message - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/x-crash-detected-error-message/</link>
                <lastBuildDate>Wed, 17 Jun 2026 16:14:31 +0000</lastBuildDate>
                        <title>RE: X Crash Detected error message</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/x-crash-detected-error-message/#post-689480</link>
                        <pubDate>Thu, 14 Dec 2023 13:18:38 +0000</pubDate>
                        <description><![CDATA[The MK3 series printer do not have x or Y end stops. They use sensorless homing.You could try lubricating the x axis smooth rods.  And make sure nothing touches the main frame during x axis ...]]></description>
                        <content:encoded><![CDATA[<p style="text-align: justify">The MK3 series printer do not have x or Y end stops. They use sensorless homing.</p><p>You could try lubricating the x axis smooth rods.  And make sure nothing touches the main frame during x axis movement</p><p>Regards Joan </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>JoanTabb</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/x-crash-detected-error-message/#post-689480</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/x-crash-detected-error-message/#post-689462</link>
                        <pubDate>Thu, 14 Dec 2023 10:42:22 +0000</pubDate>
                        <description><![CDATA[I think you should check the X-axis endstop switch. The X-axis endstop switch helps the printer determine the home position and prevents it from crashing into the frame. Make sure the switch...]]></description>
                        <content:encoded><![CDATA[<p>I think you should check the X-axis endstop switch. The X-axis endstop switch helps the printer determine the home position and prevents it from crashing into the frame. Make sure the switch is properly positioned and functioning correctly. You can visually inspect it for any damage or misalignment.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>caitlinstout</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/x-crash-detected-error-message/#post-689462</guid>
                        <title>X Crash Detected error message</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/x-crash-detected-error-message/#post-688806</link>
                        <pubDate>Mon, 11 Dec 2023 03:40:09 +0000</pubDate>
                        <description><![CDATA[Hello, my MK3 has been working great till now. I had a print fail and a big blob formed around the nozzle, unfortunately while I was away from the printer. First time that&#039;s happened so I fo...]]></description>
                        <content:encoded><![CDATA[<p>Hello, my MK3 has been working great till now. I had a print fail and a big blob formed around the nozzle, unfortunately while I was away from the printer. First time that's happened so I followed instructions and slowly cleaned it out and nothing visible seems damaged. The next time I tried printing, the printer would go through the pre-print calibration and then at the last corner it gave me the "X Crash Detected" message. I ran through the calibration wizard but still same message. I turned off Crash Detection and tried printing but the material was not being laid properly so I aborted. I know it's difficult to diagnose without having a look, but being new to printing I would appreciate any advice on this. I'm quite willing to replace the whole printing head if that is an option, I bought the printer from a friend so it's not super new but he's very meticulous and the printer has been well looked after. </p><p>Thank you</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>mimmo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/x-crash-detected-error-message/#post-688806</guid>
