Which printer would you recommend?
Oleg
 Oleg
(@oleg)
I'm sure you get this question a lot - what Prusa printer should I buy? I can't decide between the "full-size" MK3S+ and the Mini+ version. What would you recommend? My thoughts are:
- The price difference is of course substantial, but it's not my first concern in this case.
- The MK3S+ supports more materials, but how important that is? I'd like to tinker with metallic PLA and wood PLA. Does Mini+ support these filaments, or do I need to settle on MK3S+ in order to print those?
- Which printer is better in terms of ease of use? My first impression is that the Mini+, being a newer choice, might be equipped with more convenient devices (for example, a USB stick compared to an SD card).
- I'm not much of a tinkerer and prefer more of a "plug and play" experience. Which printer is better from that perspective?
- Is Prusa planning to release an MK4 any time soon? Should I wait for a better full-size option?
I'd appreciate advice from the users that own these printers and know the differences
Thank you in advance!
Veröffentlicht : 27/12/2020 3:39 pm
K7ZPJ
(@k7zpj)
RE: Which printer would you recommend?
All 3d printers are going to take a bit of "tinkering" to get them to work.  You will need to learn how to get the first layer the correct thickness.  It is something you have to learn by doing and takes patience not to give up.   It's like riding a bike, after you learn it, it comes naturally.  But you do fall off.
If you are sure that you will like 3D printing then and not give up on it then, buy the MK3+.   It has the ability to do more such as using the MMU2S.  Prusa so far has offered upgrades to their printers so when the MK4 comes out, you upgrade yours.
If you aren't sure if you are going to like 3D printing, then the Mini+ is a good option since that would be less money just sitting around in the closet  collecting dust.   However, the Mini+ is a very capable 3D printer and makes a good starter printer.
You will need to learn how to troubleshoot the printer when you have problem and have to learn how to the maintenance to keep it running. If this isn't something you like to do, you need to factor that in your decision to purchase a printer or not.
Veröffentlicht : 27/12/2020 4:28 pm
Oleg
 Oleg
(@oleg)
@k7zpj
Thank you for your advise, I appreciate it!
I started with the XYZPrinting DaVinci as my starter printer. It worked well and printed decent prints with minimal "tinkering", until their support sent me a bad extruder as a replacement for the one I got clogged (trying to print an unsupported type of filament) and the printer doesn't print anything anymore. The logical solution would be to replace their $100 extruder, but I'm so frustrated with their support (or the lack of) that I'm reluctant to put any more money into that brand.
I turned to Prusa for their great quality and support that tops all the reviews. To help me better understand my choice, can you please tell me - does the Mini+ support metallic filaments and "wood" filaments, like Metallic PLA and Wood PLA?
Veröffentlicht : 27/12/2020 5:18 pm
@oleg
Ok, mine is a Mk3 so I don't know the Mini  - but both those filaments are well within the working parameters of the Mini so, as long as you change to the appropriate nozzle for each filament, I would expect good results.
Veröffentlicht : 27/12/2020 5:35 pm
K7ZPJ
(@k7zpj)
Posted by: @oleg
@k7zpj
@oleg
Both the Mini+ and the MK3S+ support wood / metal filled filaments since the plastic base is PLA.   However, you would need to change to a hardened steel nozzle with a larger diameter than the stock nozzle.   You can check with the Prusa Material guide for more information on the filament specs.  Material Guide
If you download Prusa Slicer and install it for the Mini+ and MK3S+, you could look at all of the officially supported filament profiles.
I hope this helps.
My approach, if I can't decide which one I want, is to just buy both of them. 😀
Veröffentlicht : 27/12/2020 7:27 pm
I have both, an MK3S and a Mini. The Mk3S is a more robust machine, and I prefer the direct drive over the Bowden drive of the mini, and the Mk3S standard E3D v6 hotend assembly. The Mk3S also has more options to modify the operational characteristics of the machine in its Settings menus.
From a practical perspective, however, the Mini is a very capable machine and above and beyond the other two (non-Prusa) machines I own in that price range. No problem with PLA-based wood or metal filaments.
Personally, I prefer the Mk3S, mostly because of the larger print surface (I frequently print game inserts and functional parts). And just a small thing but important for me because I switch frequently between textured and smooth plates: The Mini doesn't allow you to store sheet profiles in memory. It's supposed to come in a future firmware release but at this moment only the Mk3S supports this feature.
Veröffentlicht : 27/12/2020 8:22 pm
3 weiteren Personen gefällt das
Mitglied
Posted by: @fuchsr
I have to agree with this.
Veröffentlicht : 28/12/2020 1:34 am
eddiemorse
(@eddiemorse)
I found this discussion useful at the right time, because I am also looking for a good printer. Thanks!
Great and useful website: Scholarsintel.com
Veröffentlicht : 16/06/2021 10:38 am
