When do we need to replace the head bed for i3MK3S/3S+?
prusanewuser
(@prusanewuser)
Hi, during several XYZ calibrations, my nozzle hit the head bed violently. Paper was torn. I can see some blocks of brown rectangles on it at different corners. Do I need to replace it? When is the time to do so?
Opublikowany : 12/04/2021 2:21 am
jsw
 jsw
(@jsw)
RE: When do we need to replace the head bed for i3MK3S/3S+?
Do you have a photo of the damage?
I know that in some cases the nozzle being driven strongly into the printbed can be due to a bad Pinda, or a Pinda badly out of vertical adjustment.
Opublikowany : 12/04/2021 2:25 am
prusanewuser
(@prusanewuser)
There you go
Opublikowany : 12/04/2021 2:59 am
I had something similar due to simple wear. Someone suggested automotive enamel paint -- the type for engine blocks -- as an easy fix. I've applied some and used it for months since with no issues. If you're not having any printing abnormalities, that may be all you need.
Opublikowany : 12/04/2021 4:01 am
1 ludzie polubili
prusanewuser
(@prusanewuser)
Posted by: @bobstro
If painting something on top, won't that cause unevenness in layer height and perhaps temperature?
Opublikowany : 12/04/2021 4:26 am
