water dispenser adapter
Hi Guys,
I just joined a company that have an i3 MK2S, and don't use it. 🙂 So now I'm just researching to see how all this new world works.
So, for my first project, here, I have a water dispenser in my work, and i want to be able to refill my tupperware bottle with water, but the place to put it is small. So, I´m thinking of doing an adapter do insert in the output of the water dispenser and then i can refill my bottle without lick water or using multiple individuals' glasses to refill. 🙂
In repository have something similar to this ?
Thanks
RE: water dispenser adapter
Hi and Welcome!
Looks like you want an offset or angled funnel. Try searching the prints section. I know there are some on Thingiverse.
Be careful with plastics selection though, you would want something reasonably safe for drinking water and be able to clean.
Potential pitfalls are: lower temperature plastics would not be dishwasher safe, some plastics might be considered toxic and all 3D printed parts can have small voids that can breed bacteria.
Good luck and
Happy Printing!
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говоÑÑ Ð¿Ð¾-ÑÑÑÑки но не оÑÐµÐ½Ñ Ñ
оÑоÑо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Thanks for help and warning tips,
I had never thought about it. 🙂
I took a look at thingiverse but didn't find it. Can you suggest a word to search or the piece?
Best Regards
If you search on Prusa Prints for 'funnel' there are lots of options. https://www.prusaprinters.org/search/prints?q=funnel
Thanks for reply,
I was searching but didn't find nothing like this:
Dr. Fill's Water Tunnel - The All Fill - No Spill Water Bottle Funnel : Amazon.co.uk: Home & Kitchen
The Fridge Funnel : 8 Steps (with Pictures) - Instructables
Of course, when i learn more i will do my own, but now will be my first print hehe
Thank you all
You can scan one adapter and then print it.
hmm i didn't get it? Scan it? Can you explain better 🙂
Thanks for reply,
Thank you all
I'm a little bored so I'll model a version of Dr Fill's funnel for you. Do you have a Prusa MK3s or a Mini? Do you know how to use PrusaSlicer if I send a .3mf?
Here this should work. I don't know how big the mouth on your bottle is, so let me know if there's anything I should change.
Hi matt,
WHATTTTTTTTTTT?? 🙂
I never used one, but I'm reading the manual and seeing YT Vídeos and this forum.
I never printed anything. Next week i will test the 3d printer, because is in another location, is brand new never used. Hehe
The ideia is that the mouth will be smaller than normal to use in a lot of bottles. Later i can change and play with that right? 🙂
I can´t see any file in the post.. is supost to download anything?
Here's the gcode if it will attach. Its only 5mb so it should work.
I posted it as a print. OFFSET FUNNEL
You can download the gcode from there
I'm open to suggestions too. You want a bully bar on the front to kick the water on?
One thing i thought now is if the bocal will contemplate cold and warm water. But maybe when i print it and test it i can adjust...
