VPN blocked by forum.prusa3d.com?
andhson
(@andhson)
The forum worked fine from behind a VPN for the first few months, then a few days ago the forum is not available from within my normal VPN, I can still use the tor browser to access the forum, it also works fine if I don’t use the VPN. Are others seeing this or do I have a local problem with my VPN being blocked.
/Anders
Opublikowany : 27/02/2025 12:49 pm
RE: VPN blocked by forum.prusa3d.com?
I can access from a vpn (PIA)
Opublikowany : 27/02/2025 6:05 pm
andhson
(@andhson)
Posted by: @neophyl
Thanks, it turns out that I can access via some VPNs but not one specific VPN provider, I will continue debugging that specific provider.
/Anders
Opublikowany : 27/02/2025 7:24 pm
_KaszpiR_
(@_kaszpir_)
it's probably cloudflare blocking certain vpn endpoints
Opublikowany : 27/02/2025 9:02 pm
andhson
(@andhson)
In my case NordVPN is the one giving me issues, CloudFlare works, so does the TOR network with an onion VPN. I registered an issue with NordVPN to check from their end, if nothing else work I will just need to set up a split tunneling exception for this forum and connect via the TOR network.
/Anders
Opublikowany : 28/02/2025 7:16 am
This is not uncommon but usually temporary.
If website security software detects an attack from one particular source it may block that ip address, often this is a single malicious user or a compromised machine being used a relay - but if an attack is sent through a VPN then it's the local VPN node that's blocked ... unfortunately genuine users using the same node get caught in the crossfire.
Opublikowany : 28/02/2025 11:39 am
Nemo2501
(@nemo2501)
I had the same problem with Nord VPN these days. In my case it was the thread protection feature causing trouble. Deactivating it helped and everything is working again.
Opublikowany : 28/02/2025 11:44 am
_KaszpiR_
(@_kaszpir_)
You should be able to report such IPs to the VPN provider and they can try to talk with other companies to clean it off, sometimes it happens.
Opublikowany : 28/02/2025 12:42 pm
andhson
(@andhson)
Posted by: @diem
I have a personal ip service so others should not use it, but likely my VPN provider has a whole range of ips, if the range is blocked I still get caught in that mess, that is the downside of using VPNs.
/Anders
Opublikowany : 28/02/2025 1:25 pm
andhson
(@andhson)
Posted by: @_kaszpir_
Yes, I have reported it to my VPN provider, not much more I can do unless I set up split tunneling exceptions, I may end up there in the end.
/Anders
Opublikowany : 28/02/2025 1:30 pm
andhson
(@andhson)
I turns out NordVPN has a security feature that blocks malicious websites, since a few days this forum is blacklisted. Luckily that feature can be turned off. Now things work again.
/Anders
Opublikowany : 28/02/2025 9:24 pm
