Verifying you really have PETG
Page 1 / 2
RichardSchreier
(@richardschreier)
I recently bought some PETG Prusafilament in a variety of colours. I tried a test print with gr5eay and it worked fine (needed some z-axis adjustment). Then I tried white and the filament ran like crazy... even before it started printing,  a blob of plastic was dripping out of the nozzle head. The same temperature settinig were used for the grey PETG I had used earlier.
I am wondering if I got shipped a PLA filament in a PETG box in error? PLPA has a lower melting point and perhaps the higher temperature of the PETG setting is causing an issue. Is there a way to tell PLA and PETG apart without actually putting it on the printer or do I just have to trust what it says on the box?
Thanks... Richard
Publié : 17/05/2021 3:03 pm
RE: Verifying you really have PETG
Great question.  Look for labels under labels on the spool. Sometimes the folk rebranding filament will just paste over the mfg label.
Postulating here: Glass temp is one way to determine the class of filament, but even that's unreliable because the eutectic point of compounds can be all over the map. Using solvents on the material is another way you can gain insight, but then some of the solvents you'd want to use are quite nasty stuff to have around.
It really comes down to trust, and why name brands can be worth paying for.
Publié : 17/05/2021 4:29 pm
Yveske
(@yveske)
I would like to know also, not for printing, but for recycling...
Having problems with bed adhesion every morning...
Publié : 17/05/2021 5:51 pm
Membre
I have a few unlabeled spools and would love to know what the heck they are.
Publié : 17/05/2021 6:04 pm
Maybe not trust what's on the box but what's on the spool. Given their Prusament QC process I think the likelihood that that there's PLa on a spool labeled PETG is close to nil.
Publié : 17/05/2021 6:05 pm
Membre
@fuchsr
True with Prusament, but some companies do not label and Hatchbox has a propensity to peal off.
Publié : 17/05/2021 6:07 pm
@cwbullet
Oh, I totally get that. I have oodles of leftover filament or samples and no idea what material they are. I was responding specifically to the OP's mentioning of Prusafilament [sic] which I assumed was a misspelling of Prusament.
Publié : 17/05/2021 6:21 pm
RichardSchreier
(@richardschreier)
Well, the label on the spool does indeed say PETG but for fun I test printed the configuration file with PLA settings and it worked fine, given it drips and blobs like crazy at PETG settings I am going to assume it must be PLA. Any additional thoughts? Thanks
Publié : 17/05/2021 6:30 pm
@richardschreier
Can you tell the difference between butter and margarine by the melting point?
If the label says PETG, but your normal PETG temps creamify it, print it at PLA temps, but assume it is PETg for applications. Though, I probably wouldn't use a part made from it in a car.
ps: I've printed Prusament with a PLA profile... can't say anything bad happened. I've even printed PC with a PLA profile. Who knew?
Ce message a été modifié il y a 4 years 2 fois par --
Publié : 17/05/2021 6:38 pm
Same here. I've printed PLA with PETG profile and vice versa.
Publié : 17/05/2021 6:43 pm
Membre
Good points - if it is too runny, it is PLA, if it perfect at 230-240, it is PETG.
Publié : 17/05/2021 6:45 pm
Membre
Posted by: @tim-2
@richardschreier
By taste?  I am not tasting PLA or PETG.
Publié : 17/05/2021 6:50 pm
@cwbullet
They taste like chicken...
Publié : 17/05/2021 6:56 pm
Baklin
(@baklin)
This doesn't apply for all filaments. But I have many spools of Real filament and their PETG is more shiny on the spool compared to their PLA. Most of the time I can pick the right spool without first looking at the label.
But the Prusament spools I have don't have that clear difference.
Publié : 17/05/2021 7:00 pm
Membre
@fuchsr
Mmm, chicken.
Publié : 17/05/2021 7:17 pm
Maybe not, but you can smell them.
Or rather, their smoke.  Burn the end of a scrap of filament and smell the smoke (just a waft, not a megasniff, do it away from the smoke alarm and over a bowl of water, you don't want burning drips of molten plastic hitting the carpet.) Smoke from scorching PLA and PETG smell quite different...
...but I don't know how much the pigment contributes.
Publié : 17/05/2021 10:25 pm
REIFY 3D
(@reify-3d)
If it's Prusament, scan the spool's QR code and see what it says on the website. Then get in touch with their support. I've had issues with Prusament Neon Green PETG and after submitting photographic evidence of a manufacturing anomaly, they gave me a discount voucher for my troubles.
Publié : 17/05/2021 11:33 pm
Thejiral
(@thejiral)
Distinguishing PETG from PLA should be relatively straight forward. If you print something and smell those lovely unhealthy fumes (also PLA isn't exactly health improving but not that bad, compared to other polymers). Especially PLA has a very distinct smell I think, butyric acid like? (well probably like lactic acid as that is its monomeric composition)  Just take a whiff of a trusted PLA of your choice and you know what I mean.
PETG doesn't smell like that all. It smells more like you would imagine molten plastic smells like. Not very strong but maybe soapy (if that is a smell) and headache inducing when smelling it longer (which you shouldn't I guess). Identifying PETG by its smell might be harder but PLA should be fairly clear.
Also PLA is harder than PETG but the more it hydrolyzes, the more brittle it gets. PETG is more flexible and a bit softer.
Publié : 19/05/2021 8:19 pm
-- a aimé
Peter M
(@peter-m)
Make a temp tower, possible you need less temperture to print the petg.
PLA should smell different, print petg then print pla , to compare.
Publié : 21/05/2021 3:54 pm
Membre
@peter-m
Good point.  PLA often smells sweet (not sure that is the right term).  It has a very distinctive odor.
Publié : 21/05/2021 4:01 pm
Page 1 / 2
