Unable to upload SKP file to PrusaPrinters
smartroad
(@smartroad)
Just updating a model (the listing was created using the Thingiverse Import but I doubt that is where the problem is, but for clarity) and I have been able to upload new 3mf files but it will not allow me to upload the SketchUp file throwing up the attached error.
Anyone have thoughts on the problem? 😀
Attachment removed
Opublikowany : 16/11/2019 10:45 am
Zoltan
(@zoltan)
Member Moderator
RE: Unable to upload SKP file to PrusaPrinters
Zip it to .zip format. Zip is accepted to upload
Opublikowany : 16/11/2019 11:25 am
smartroad
(@smartroad)
@zoltan
Thanks for the pointer. According to the edit page:
Supported files: .gcode, .stl, .3mf, .f3d, .obj .amf, .scad, .dwg, .dxf, .stp, .step, .3ds, .blend, .svg, .skp, .jpg, .png, .gif
so I should be able to upload skp files. The question becomes is it an error in my file or site error.
Opublikowany : 16/11/2019 11:47 am
smartroad
(@smartroad)
Okay, just tried to upload the zip file after trying the skp file and now when the zip uploads the skp file appears! I'm so confused!! LOL
Opublikowany : 16/11/2019 11:51 am
rmm200
(@rmm200)
Well you are consistent. None of the files you tried to upload are showing here. Or maybe you did not try to post your file here.
Is this a web site problem? You have no problem with PrusaSlicer or the actual printer?
I - think - you are just trying to store your model in the Prusa repository.
Opublikowany : 16/11/2019 6:23 pm
Sembazuru
(@sembazuru)
Posted by: @robert-rmm200
Looking at the subject of this thread the OP is talking about uploading model files to the PrusaPrinters repository (Prusa's take on Thingiverse). That is why no files are showing here...
See my (limited) designs on:
Opublikowany : 18/11/2019 8:12 pm
