Unable to print from downloaded files
Seite 2 / 2
Graham
(@graham)
RE: Unable to print from downloaded files
Hi Joan,
The test file loaded into the printer which hasn't happened befor so we are getting somewhere. Unfortunately, after printing a line down the LHS of the bed it then throws an error....
Unable to parse move 'G1 X 0.4 Y 20 Z 0.30.2 F 1500.0 E 30; Draw the second line'
At least you've given me something to tinker with.
Many thanks for your help.
Graham
Veröffentlicht : 13/02/2024 8:14 pm
Cheers
Joan
Veröffentlicht : 13/02/2024 8:26 pm
JimB
 JimB
(@jimb)
Note the Z value: 0.30.2
That looks like it is coming from Printer Settings -> Custom G-code -> Start G-code (that is an expert mode option).
G1 X0.4 Y20 Z0.3[first_layer_height] F1500.0 E30 ; Draw the second line
My guess is that you need to remove the "0.3" after the "Z"
Veröffentlicht : 13/02/2024 10:30 pm
miroslav.h4
(@miroslav-h4)
To @jimb
That's right, the error comes from Prusa Research and is exactly in the place you describe. The line should look like this:
G1 X0.4 Y20 Z[first_layer_height] F1500.0 E30 ; Draw the second line
The startup gcode in the printer profile needs to be modified according to your design, save the profile and use it instead of the original one.
Veröffentlicht : 14/02/2024 6:12 am
Seite 2 / 2
