Tools: What do you recommend?
Stránka 13 / 17
sledjunk
(@sledjunk)
RE: Tools: What do you recommend?
Posted by: @charles-h13
I would not like to recommend either a Raspberry PI 3 or 4.  I have Octoprint installed on each printer and I am very happy with the results.  I have them connected through the pin headers and an RPI cable from a Little Red Toaster.  It allows both data and power to go from the MK3S to the PI. Unfortunately, the Mini is not capable of this connection but can be connected by USB.
This tool/upgrade will allow you to monitor your prints with Astroprint with an added plugin. PI 4 is preferred because ti adds significant speed over the PI 3.  The 3d printed einsy and raspberry controller box below alloys the addition of a Buck Converter.  I have never needed one.
Parts:
Printed parts:
Enjoy!  I am adding one to my new printer and will post pictures as i assemble it.
I had planned to install Octoprint and Raspberry Pi when I got started in this hobby, but I have been very happy simply running Pronterface on a laptop connected via USB.  I have also added a mini camera to watch the printer.  I can remote into the laptop via AnyDesk or TeamViewer, and control and watch the print.  Very easy and convenient.
Drinking alcohol can cause memory loss. Or worse, memory loss!
Napsal : 05/09/2020 4:55 pm
@bobstro
No performance benefit.  For me, it is all about powering it through the printer.
Napsal : 05/09/2020 5:21 pm
I would now like to recommend either a Raspberry PI 3 or 4.  I have Octoprint installed on each printer and I am very happy with the results.  I have them connected through the pin headers and an RPI cable from a Little Red Toaster.  It allows both data and power to go from the MK3S to the PI. Unfortunately, the Mini is not capable of this connection but can be connected by USB.
Parts:
Printed parts:
Slight typo:
This tool/upgrade will allow you to monitor your prints with Astroprint with an added plugin. PI 4 is preferred because ti adds significant speed over the PI 3.  The 3d printed Einsy and raspberry controller box below alloys the addition of a Buck Converter.  I have never needed one.
Parts:
Printed parts:
Napsal : 05/09/2020 5:23 pm
3Delight
(@3delight)
Moderátor Moderator
All I use is the kit Prusa sent with my MK2, some alcohol wipes, a set of different width wallpaper scrapers, and that's it!  I use the Prusa pliers to pull of bits of filament that dribble out the nozzle, and the wallpaper scrapers to remove prints from the bed.  So far I haven't needed anything else.
Never lubricated it, just wiped off the little bit of dust  that gets on it in it's enclosure (a metal/glass server cabinet), and it still prints perfect.
Napsal : 05/09/2020 5:52 pm
@3delight
It is not that they are needed, I just like better tools.
Napsal : 05/09/2020 5:53 pm
3Delight
(@3delight)
Moderátor Moderator
Sorry, I wasn't criticising!  I'm sure when something does come up I'll regret not having more tools at hand! 🙂
Napsal : 05/09/2020 6:33 pm
jsw
 jsw
(@jsw)
I don't use Octoprint (yet) but I've used the Pi series almost as long as they have been readily available.
The Pi 4 is not too shabby at all.  Really!
A few months ago the PC I had down in the train room crashed, and for a quickie makeshift I subbed in a Pi 4, intended to be temporary, to get things going, and was quite impressed with the performance.  It actually makes a fairly decent low-expectation desktop.  All I really use it for down there is logging into things (mostly other Pi boxes on the model RR), casual web surfing and minor schematic editing and such.
That little box really gives a lot of bang for the buck.
Napsal : 05/09/2020 8:11 pm
@charles-h13
I would not recommend cheap buck converters, because they do not provide stable voltage for the Pi and can even damage the power supply.
Napsal : 05/09/2020 8:43 pm
@karl-herbert
I did not use it,  but good advice.  I have one because it was recommended on Thingiverse.  I chose to wire it with the RPI connector instead.
Napsal : 05/09/2020 8:45 pm
@bobstro
I have also connected my Pi 3B+ to the Einsy via GPIO. Current baud is 250000 and the Pi is supplied by an external stabilized 5.2V power source.
Napsal : 05/09/2020 8:50 pm
jsw
 jsw
(@jsw)
I just installed a Pi Zero as a temperature monitor for the new enclosure and I really didn't even think of powering it off of the printer.  Those USB power bricks are dirt cheap and the Pi, even the 4, is really not that picky about the power you give it as long as you give it adequate current.  (I hate seeing that lightning bolt on the Pi screen.)
Napsal : 05/09/2020 9:12 pm
@jsw
I am running out of sockets on my power back up.
Napsal : 05/09/2020 9:16 pm
jsw
 jsw
(@jsw)
@jsw
That's what cube taps and octopus plugs are for.  😉
Napsal : 05/09/2020 9:21 pm
@charles-h13
I have installed a distribution box in my printer enclosure. Various consumers are connected and secured to this box. For this reason I only need one power plug. LAN (Pi connection) and USB for flashing the firmware (printer and MMU2) are mounted on the outside of the enclosure.
Napsal : 05/09/2020 9:34 pm
Not_Dave
(@not_dave)
Two tools I absolutely love for building the kit and for general maintenance is the Wera 2.5mm Allen screwdriver (hex plus - not the ball head), no more messing about with tiny fiddly allens, Quick easy and secure, never lose it and cheap for such a high quality tool.
https://www.amazon.co.uk/Wera-05118070001-Screwdriver-2-5x60mm-Hex-Plus/dp/B000XJ1LIS/ref=sr_1_1?dchild=1&keywords=wera%2B2.5&qid=1599392372&quartzVehicle=112-1489&replacementKeywords=wera&sr=8-1&th=1
And: Hartman's Alligator Forceps, these are great at getting things into and out of small spaces especially tight nuts and washers, or fishing screws out from hidey holes.
I keep a set of matching set op spanners in 5.5mm (nuts), 7mm (nozzle), 16mm (heater block) and 3mm drill bit for m3 hole reaming, with the printers alongside the standard vernier calipers,  side cutter IPA bottle and all the other little bits that accumulate.
Napsal : 06/09/2020 11:52 am
Clemens M.
(@clemens-m)
Posted by: @jsw
Same to me - I have 3 of the Pi4 4GB running as desktop computers, where I do CAD-work, slicing, firmware configuration and compiling and so on. It is really impressive how that little peace of curcits performs. I love them! Overall I have more than 20 of them - at least one of every model they released.
What is the adventage of not connecting the Pi using a USB-cable but these connectors on the GPI?
Best regards, Clemens
Napsal : 06/09/2020 12:25 pm
jsw
 jsw
(@jsw)
I have a couple of Pi projects that power the Pi from another device through the bus connector.  Advantage is that it needs one less power supply, but it really depends on the circumstances of the project.
In terms of the enclosure, it was close to a no-brainer.  More hassle connecting it in to the printer supply than to simply run a cable out to a power brick.
Napsal : 06/09/2020 1:22 pm
@jsw
No hassle.  To me, it was fewer power bricks and fewer USB connectors to break off or get in the way during repairs.  The cable is now self-contained in the casing.
Napsal : 06/09/2020 2:11 pm
@clemens-m
The advantage is powering off the Einsy and no external USB cables to clutter or get in the way.
Napsal : 06/09/2020 2:12 pm
towlerg
(@towlerg)
I'm sure some peeps successfully run Pi's in various ways but I would point out that 2 commonly recurring threads (apart from trying to use the zero) are power (both V and A) and using GPIO instead of USB (often the wrong UART is configured).
Napsal : 06/09/2020 2:38 pm
Stránka 13 / 17
