tiny layershift
boomfist
(@boomfist)
tiny layershift
I tested the belts > perfect
callibrated Y and X axis
full selftest > perfect
checked if nozzle and hotend are solid in place > solid in place
anyone anymore ideas?
the shift is in both X and Y in the same Z height
FYI: i'm printing with a 0.25 nozzle with a layerheight of 0.10 and the normal basic speedsettings that come with the software. so no extreme speeds or anything.
Ce sujet a été modifié il y a 10 months par boomfist
Publié : 26/08/2025 8:17 am
_KaszpiR_
(@_kaszpir_)
RE: tiny layershift
Without PrusaSlicer project or a model it is hard to to give more suggestions. It may suffer from the known 'benchy hull line' issue.
Publié : 26/08/2025 10:46 am
RE: tiny layershift
Without pics from all sides its hard to tell, especially with white filament.  However from what I can see it does not look like a layer shift.  Layer shift is where everything is shifted over in one direction, so it sticks out one side but is in by the same amount the other side.  What you have pictured looks like Z banding.  It even looks like a regular Z banding pattern as its repeated at regular intervals as it moves up the print.
Publié : 26/08/2025 3:47 pm
Tim
 Tim
(@tim-21)
Membre
RE: tiny layershift
If there is a hole or other feature at those levels - there are many threads discussing the issue in depth.  Another cause when there are no features in the part is the filament spool - some filaments have whacky variation in diameter as the filament is extruded and loaded onto the spool during manufacturing, that +/-0.05 or +/-0.08 spec.
Publié : 31/08/2025 5:26 am
