the Pulley
Can a Pully cause issues with right tension or or getting y-crashes when printing?
my belt keeps moving to the left on the pulley is that an issue, or is it negligible, or does it need to be in the center of the pulley?
also i have tried to push the bed back and forth with the belt on the left and then manual push the belt to center and it is just a little easier to push the bed back and forth.
Belt on the left side of the Pulley
Publié : 13/09/2019 8:49 pm
RE: the Pulley
Belt centering on the pulley is a "don't care".
If the bed is hard to move, you've probably tightened the U-bolts too much. This crushes the bearings and causes crashes. U-bolts should be adjusted until they just wiggle, then a slight 1/8th turn of the nut to stop the wiggle.
Publié : 13/09/2019 9:42 pm
