Sometimes the top layer warps
Laura Capellades
(@laura-capellades)
Hi there!
I’m having this problem, and I don’t understand why it’s happening. With some models that have curved bases, when I print them, the first few layers seem to warp, while with other models, they come out perfect—solid and straight. I’m not even sure if the problem is with the first layer… I don’t understand why this happens since I’m using the same print settings. Any suggestions?
Thank you so much!
Laura
Publié : 19/03/2026 4:02 pm
Laura Capellades
(@laura-capellades)
RE: Sometimes the top layer warps
I think this is the difference (image). For some reason, the first layer always ends up smaller. If I upload a simple cube, it does the same thing, and then it distorts the text underneath. I don't understand why most people make this first layer thinner...
Publié : 19/03/2026 10:25 pm
Show us a picture of the underside of a failed print then save your project as a .3mf file
Files > Save Project as
Publié : 20/03/2026 10:00 am
Laura Capellades
(@laura-capellades)
En cuando pueda lo cuelgo. Pero pueden probar con cualquier cosa. Cargar un cubo y ponerle un volumen negativo en la base. Al laminarlo con Prusa sale deformado, si lo lamino con otras maquinas sale correcto (utilizando perfiles por defecto). Antes esto no me pasaba.
Publié : 20/03/2026 12:23 pm
Laura Capellades
(@laura-capellades)
exemple investigar
Adjunto el ejemplo.
Muchas gracias por la ayuda,
Thanks!
Publié : 20/03/2026 1:56 pm
Laura Capellades
(@laura-capellades)
I discover the problem! Elephant foot compensation! This was a problem! resolved
Publié : 20/03/2026 4:10 pm
