Smooth PEI sheets out of stock
Well I know the powered coated sheets have always been a problem (my mk3 came with one), but now I want to order another smooth sheet, they are out of stock,. d'oh. How often does this happen ?
Texy
RE: Smooth PEI sheets out of stock
I have never seen it happen. Have you contacted through Chat?
No - should I need too ? If it's in stock then I would expect it to show a such on the relevant eshop webpage, surely ?
Anyway I clicked the button for notification for when it is back in stock, but I am just surprised that it went out of stock at all.
Texy
You can just wait or you can ask if they have an estimate on availability.
See friday's blog post.
Right! It was a large article, but I found what you are referring too. So the answer (famous last words) is that they should be back in stock next week.
Good reference, thanks. Also gave me a chance to poke them about initial cleaning on PC sheets.
...they are back in stock...and ordered 😀
Texy
Texy
Texy,
When you receive it, can you circle back and post the version or batch ID in the top left corner?
Texy
Texy,
I'll try and remember 😀
I recently bought a second hand prusa Mk3s, but it looks like I only can order sheets with the original account which bought the machine, is that right?
Click on EShop, then the Chat button in lower right.
Support can fix you up.
I'm not sure if these are the actual Prusa sheets, but filamentone sells adhesive PEI sheets for the Prusa sheets. My personal favorite are the PrintedSolid steel sheets with the BuildTak PEI surface. The PS steel sheet is thinner and very flexy, and the BT PEI uses an adhesive that is much easier to remove and replace for future repair jobs.
The Buildtak PEI is fantastic. I have a sheet with it and it is equal or superior to the Prusa PEI.
Texy
Texy,
delivery took a while as I missed DHL and had to get it redirected to work.
Anywho, the answer is PA-11
Hope this helps,
Texy
@texy
PA-11 is definitely a new patch. Let us know how it holds up.
Try contacting them through chat.
Who should contact the chat? Hexy got a sheet.
Yeah, keep up at the back 😂
the new sheet is performing ok. I’m still getting some with large pla prints, but that’s typical. First layer is stick well however.
I meant to say I get some corner lifting on large PLA prints.....
