slicer3d pe and inport from Fusion
pbnj
 pbnj
(@pbnj)
I have a part that was generated by Fusion 3d using English measurements. When I import it, the part is very small. Help, what am i doing wrong. simplify 3d gets it correct when it imports it.
Posted : 04/08/2018 10:36 pm
Re: slicer3d pe and inport from Fusion
multiply by 25,4
2540%
i think! 😯
Joan
Posted : 04/08/2018 10:39 pm
next time, model in mm, it's easier!
Joan
Posted : 04/08/2018 10:40 pm
Cameron
(@cameron)
If you switch the units in Fusion to mm prior to saving the .STL, the STL will open properly in Slic3r. You can change the units back to what ever you want after you have saved the .STL
Posted : 05/08/2018 1:42 am
one day you will forget which unit you are using!
Joan
Posted : 05/08/2018 1:57 am
