Slic3r PE support not working as it should
SeroS
(@seros)
I Made a cellphone case in Fusion 360,and when i slice it with the Slic3r PE, with the support option, the program don't use support where it should, or is at least what i think, anyone can tell me if i'm wrong. Here are 2 pics of 2 consecutive layers.
I know i can rétate my model, but i what to fix the support material problem.
Regards Rodrigo
Posted : 23/07/2018 5:10 am
Re: Slic3r PE support not working as it should
Look through the layers from the top down. Are those right before the open air showing as "bridged"? If so, under Print Settings->Support Material->Options for support material and raft you probably want to try turning off Don't support bridges. It'll probably print better rotated though.
Posted : 23/07/2018 3:45 pm
SeroS
(@seros)
I know you writed this long time ago, but i forgot to thank you, so...
THANKS.
Posted : 23/01/2019 12:26 am
