prusaslicer print settings
Mishel
(@mishel)
I have a question, how can i Set in the prusaslicer settings like I want to print the big part in (0.20 mm speed) and the small parts like name for example, to print in (0.15 mm quality).
I have a large model and below it there is a small name, but my problem is when I do a 0.15mm quality the print time more than one day, but if I change to more mm like (speed of 0.20mm) then the name does not come out well at all.
If that is possible.
Veröffentlicht : 10/09/2021 3:57 pm
You can use modifier meshes. See https://help.prusa3d.com/en/article/modifier-meshes-custom-supports-and-other-magic_114258/. For example, you can set layer height to 0.1, then right click the large part and select "Layers and Perimeters" and set layer height to 0.2 just for that part.
Veröffentlicht : 10/09/2021 4:37 pm
Swiss_Cheese
(@swiss_cheese)
@mishel
You can change layer heights of parts that are (separate objects), you will not need a modifier to do this, you will want to right click on the object and select "Layers and Perimeters" from the resulting menu. In the lower part of the window pane to the right you will see a dialogue appear "Object settings to Modify" you can make changes to (individual objects) here.
However, If the words and the model are one object you will only be able to change the layer height for an entire range (selection of layers) of the model with in a Height Range. this can be done using either the "Variable layer height tool" or a "Height range modifier" Note: both of these tools will effect the layers of the entire height range selected for that object.
If you would care to post a ZIPPED up .3mf project file I will take a look, and perhaps provide an example.
Good Luck
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 11/09/2021 8:30 pm
Mishel
(@mishel)
I managed thanks to you guys, thank you
Veröffentlicht : 12/09/2021 9:53 pm
