PrusaSlicer is not working for me: HELP
DrSteve52
(@drsteve52)
I was doing pretty well with Prusa Slic3r PE and my prints were fine.
I installed PrusaSlicer 2.0 and have not had a successful print since.  When I slice the image disappears from the preview mode. I also notice that there is no information as to the amount of filament used etc.  The printer appears to be making the effort to print however I am only getting spaghetti.
I no longer have Prusa Slic3r PE and the folders for the configuration appear to be empty.  Please advise on what I am doing wrong, and how to correct. Thank you Steve
Posted : 15/07/2019 1:42 am
RE: PrusaSlicer is not working for me: HELP
Did you run through the configuration assistant and select the options for your printer?
The part should show in normal and preview modes. It will disappear from preview while slicing, but should reappear once done. Toggle between the 2 boxes at bottom-left of the screen (ab0ve the View box).
Posted : 15/07/2019 1:51 am
DrSteve52
(@drsteve52)
Thanks for the fast reply. I had run it but something must not have been correct. Ran it again and all is well.
Much appreciated.
Posted : 15/07/2019 2:10 am
