PrusaSlicer 2.0 doesn't show new objects
john.m73
(@john-m73)
As the title states, when I create a new project and import a stl file, the object will not be rendered in the viewing window. I have to completely close PrusaSlicer 2.0 and reopen it to see objects.
Advice?
here's copied system spec
PrusaSlicer
Version: 2.0.0+win64
Build: PrusaSlicer-2.0.0+win64-201905201652
Operating System: Windows
System Architecture: 64 bit
Windows Version: Windows 10 (build 17134), 64-bit edition
OpenGL installation
GL version: 4.6.0 NVIDIA 417.22
Vendor: NVIDIA Corporation
Renderer: GeForce GTX 1080/PCIe/SSE2
GLSL version: 4.60 NVIDIA
Installed extensions:
GL_AMD_multi_draw_indirect
GL_AMD_seamless_cubemap_per_texture
GL_AMD_vertex_shader_layer
GL_AMD_vertex_shader_viewport_index
GL_ARB_ES2_compatibility
GL_ARB_ES3_1_compatibility
GL_ARB_ES3_2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_bindless_texture
GL_ARB_blend_func_extended
GL_ARB_buffer_storage
GL_ARB_clear_buffer_object
GL_ARB_clear_texture
GL_ARB_clip_control
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_compute_shader
GL_ARB_compute_variable_group_size
GL_ARB_conditional_render_inverted
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_cull_distance
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_derivative_control
GL_ARB_direct_state_access
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_fragment_shader_interlock
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_get_texture_sub_image
GL_ARB_gl_spirv
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_gpu_shader_int64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_indirect_parameters
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_parallel_shader_compile
GL_ARB_pipeline_statistics_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_polygon_offset_clamp
GL_ARB_post_depth_coverage
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_query_buffer_object
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sample_locations
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_seamless_cubemap_per_texture
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counter_ops
GL_ARB_shader_atomic_counters
GL_ARB_shader_ballot
GL_ARB_shader_bit_encoding
GL_ARB_shader_clock
GL_ARB_shader_draw_parameters
GL_ARB_shader_group_vote
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shader_texture_image_samples
GL_ARB_shader_texture_lod
GL_ARB_shader_viewport_layer_array
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_sparse_buffer
GL_ARB_sparse_texture
GL_ARB_sparse_texture2
GL_ARB_sparse_texture_clamp
GL_ARB_spirv_extensions
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_barrier
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_filter_anisotropic
GL_ARB_texture_filter_minmax
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transform_feedback_overflow_query
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXTX_framebuffer_mixed_formats
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_import_sync_object
GL_EXT_memory_object
GL_EXT_memory_object_win32
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_polygon_offset_clamp
GL_EXT_post_depth_coverage
GL_EXT_provoking_vertex
GL_EXT_raster_multisample
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_semaphore
GL_EXT_semaphore_win32
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_formatted
GL_EXT_shader_image_load_store
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_sparse_texture2
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_filter_minmax
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_R8
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_EXT_win32_keyed_mutex
GL_EXT_window_rectangles
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_blend_equation_advanced
GL_KHR_blend_equation_advanced_coherent
GL_KHR_context_flush_control
GL_KHR_debug
GL_KHR_no_error
GL_KHR_parallel_shader_compile
GL_KHR_robust_buffer_access_behavior
GL_KHR_robustness
GL_KTX_buffer_region
GL_NVX_blend_equation_advanced_multi_draw_buffers
GL_NVX_conditional_render
GL_NVX_gpu_memory_info
GL_NVX_multigpu_info
GL_NVX_nvenc_interop
GL_NV_ES1_1_compatibility
GL_NV_ES3_1_compatibility
GL_NV_alpha_to_coverage_dither_control
GL_NV_bindless_multi_draw_indirect
GL_NV_bindless_multi_draw_indirect_count
GL_NV_bindless_texture
GL_NV_blend_equation_advanced
GL_NV_blend_equation_advanced_coherent
GL_NV_blend_minmax_factor
GL_NV_blend_square
GL_NV_clip_space_w_scaling
GL_NV_command_list
GL_NV_compute_program5
GL_NV_conditional_render
GL_NV_conservative_raster
GL_NV_conservative_raster_dilate
GL_NV_conservative_raster_pre_snap_triangles
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_draw_texture
GL_NV_draw_vulkan_image
GL_NV_explicit_multisample
GL_NV_feature_query
GL_NV_fence
GL_NV_fill_rectangle
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_coverage_to_color
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_fragment_shader_interlock
GL_NV_framebuffer_mixed_samples
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_geometry_shader_passthrough
GL_NV_gpu_program4
GL_NV_gpu_program4_1
GL_NV_gpu_program5
GL_NV_gpu_program5_mem_extended
GL_NV_gpu_program_fp64
GL_NV_gpu_shader5
GL_NV_half_float
GL_NV_internalformat_sample_query
GL_NV_light_max_exponent
GL_NV_memory_attachment
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_path_rendering_shared_edge
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_query_resource
GL_NV_query_resource_tag
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_sample_locations
GL_NV_sample_mask_override_coverage
GL_NV_shader_atomic_counters
GL_NV_shader_atomic_float
GL_NV_shader_atomic_float64
GL_NV_shader_atomic_fp16_vector
GL_NV_shader_atomic_int64
GL_NV_shader_buffer_load
GL_NV_shader_storage_buffer_object
GL_NV_shader_thread_group
GL_NV_shader_thread_shuffle
GL_NV_stereo_view_rendering
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_rectangle_compressed
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_uniform_buffer_unified_memory
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_NV_viewport_array2
GL_NV_viewport_swizzle
GL_OVR_multiview
GL_OVR_multiview2
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control
Best Answer by bobstro:
Sounds like you're in Preview mode, where you're taken after slicing a part. Try clicking the 2 buttons at bottom-left. Not at my desk to verify, but I think the left one is the one you want.
Postato : 02/07/2019 1:26 am
RE: PrusaSlicer 2.0 doesn't show new objects
Postato : 02/07/2019 1:52 am
1 persone hanno apprezzato
john.m73
(@john-m73)
Well call me a noob lol
Thanks!
Postato : 02/07/2019 1:54 am
Dave Avery
(@dave-avery)
after you slice an object you are in "preview mode" to switch back to 3d mode click on the wireframe cube in the lower left corner or hit "ctrl-5" on the keyboard
Postato : 02/07/2019 1:55 am
RAH1
 RAH1
(@rah1)
Posted by: john.m73
Thanks!
Noob.  😉
I am the inveterate tinkerer. I can tink up most anything.
Postato : 02/07/2019 3:36 am
Sembazuru
(@sembazuru)
There is a setting in the PrusaSlicer preferences for background processing. This will automatically slice your objects for you. I usually run with it turned on. I only turn that off if I'm making small adjustments with either placement of parts and/or modifiers for complex objects (constantly restarting the slicing on a complex print can make Plicer laggy).
See my (limited) designs on:
Postato : 02/07/2019 4:35 am
GregB
(@gregb)
Wow.  Thanks for asking because I've been having the same issue ;-).  Good to know!
Postato : 02/07/2019 12:16 pm
