prusaprinters.org https problems
Pagina 1 / 2
herbert
(@herbert)
Hi together,
since yesterday I do have issues with https://www.prusaprinters.org main domain using https within firefox and chrome. I wonder if I am the only one 🙂
Attached is the error message I get.
Thanks
Postato : 25/03/2021 6:47 am
adesir
(@adesir)
RE: prusaprinters.org https problems
Hello,
There was a short certificate error yesterday. It has been solved quickly. Empty your cache?
Mes modeles publics
Postato : 25/03/2021 7:27 am
herbert
(@herbert)
Thanks it works now, but had nothing to do with the cache because different PC 😉 other browser.
Anyhow, fixed, thanks
Postato : 25/03/2021 8:49 am
egar
 egar
(@egar)
I'm still having this problem today.  It worked briefly about 30 minutes ago, but all connections since give me this error.  This happens in both Safari and Firefox.  I have also cleared cookies and browsing history for this site.
Postato : 25/03/2021 1:42 pm
egar
 egar
(@egar)
Reposting the screenshot.  Apparently a little too big to fully display.
Postato : 25/03/2021 1:45 pm
Clarmrrsn
(@clarmrrsn)
Seems to be an issue for me as well.
Have cleared cache and browsing data, but still the same.
Tank you very much!
Postato : 25/03/2021 2:51 pm
egar
 egar
(@egar)
Seems to have been corrected now.  Keeping my fingers crossed that it stays that way.
Postato : 25/03/2021 2:53 pm
Swiss_Cheese
(@swiss_cheese)
I haven't been able to get on https://www.prusaprinters.org   in over a month It just spins and spins at the front page. I gave up.
The Filament Whisperer
Postato : 25/03/2021 5:15 pm
3Delight
(@3delight)
Moderatore Moderator
It's working fine for me from the UK right now.
I've reached out and Prusa are aware there is a problem and are working on it...
Postato : 25/03/2021 5:42 pm
Leooel
(@leooel)
Still not up.
Postato : 25/03/2021 6:51 pm
RC builder
(@rc-builder)
The site certificate has expired, the problem persists. After adding exception for prusaprinters.org, Prints section  displays
"There has been a critical error on this website". In Firefox and MS Edge the same behavior, cache/cookies cleaning has no effect.
Postato : 26/03/2021 10:11 am
Leooel
(@leooel)
Strange that no one can fix this problem. Judging from previous posts, this problem has been for a long time.
Postato : 26/03/2021 10:22 am
3Delight
(@3delight)
See here for explanation: https://twitter.com/Prusa3D/status/1375151786789629956
Please be patient, sometimes these things take time, and are never as simple as first thought!
Postato : 26/03/2021 11:10 am
towlerg
(@towlerg)
I use Waterfox (I really hate current Firefox) and I've never been able to access https://www.prusaprinters.org. I have to use Firefox yuk.
Postato : 26/03/2021 12:36 pm
RC builder
(@rc-builder)
It seems the issue is fixed. At least for region I use.
Postato : 26/03/2021 1:51 pm
3Delight
(@3delight)
OK Guys, the problem should now be fixed: https://twitter.com/Prusa3D/status/1375453213177040896
If your still having issues then before reporting it make sure you clear your browsers cache and flush your systems DNS cache:
On windows use the following DOS command: C:\Windows\System32\ipconfig.exe /flushdns
On Apple run the terminal and enter: sudo killall -HUP mDNSResponder
On Linux use: sudo /etc/init.d/nscd restart and then sudo /etc/init.d/dnsmasq restart
Hopefully everyone is up and running now
Postato : 26/03/2021 2:56 pm
Swiss_Cheese
(@swiss_cheese)
This seems pretty extreme to have to do to get back on a web site, whats the deal?
Postato : 28/03/2021 5:25 pm
Swiss_Cheese
(@swiss_cheese)
just a General FYI, I still can't access prusaprinters.org
Postato : 02/04/2021 4:50 am
adesir
(@adesir)
Posted by: @swiss_cheese
On every device you try? With all common browsers?
Mes modeles publics
Postato : 02/04/2021 5:27 am
Swiss_Cheese
(@swiss_cheese)
I have two browsers, Firefox and Microsoft on two different computers, one desktop one laptop and I can't gain access from either, I live in USA California. I get nothing but the spinning progress graphic
It's been weeks going on over a month.
Postato : 02/04/2021 6:30 am
Pagina 1 / 2
