prusaprinters.org https problems
Hi together,
since yesterday I do have issues with https://www.prusaprinters.org main domain using https within firefox and chrome. I wonder if I am the only one 🙂
Attached is the error message I get.
Thanks
RE: prusaprinters.org https problems
Hello,
There was a short certificate error yesterday. It has been solved quickly. Empty your cache?
Thanks it works now, but had nothing to do with the cache because different PC 😉 other browser.
Anyhow, fixed, thanks
I'm still having this problem today. It worked briefly about 30 minutes ago, but all connections since give me this error. This happens in both Safari and Firefox. I have also cleared cookies and browsing history for this site.
Seems to be an issue for me as well.
Have cleared cache and browsing data, but still the same.
Tank you very much!
Seems to have been corrected now. Keeping my fingers crossed that it stays that way.
I haven't been able to get on https://www.prusaprinters.org in over a month It just spins and spins at the front page. I gave up.
The Filament Whisperer
It's working fine for me from the UK right now.
I've reached out and Prusa are aware there is a problem and are working on it...
Still not up.
The site certificate has expired, the problem persists. After adding exception for prusaprinters.org, Prints section displays
"There has been a critical error on this website". In Firefox and MS Edge the same behavior, cache/cookies cleaning has no effect.
Strange that no one can fix this problem. Judging from previous posts, this problem has been for a long time.
See here for explanation: https://twitter.com/Prusa3D/status/1375151786789629956
Please be patient, sometimes these things take time, and are never as simple as first thought!
I use Waterfox (I really hate current Firefox) and I've never been able to access https://www.prusaprinters.org. I have to use Firefox yuk.
It seems the issue is fixed. At least for region I use.
OK Guys, the problem should now be fixed: https://twitter.com/Prusa3D/status/1375453213177040896
If your still having issues then before reporting it make sure you clear your browsers cache and flush your systems DNS cache:
On windows use the following DOS command: C:\Windows\System32\ipconfig.exe /flushdns
On Apple run the terminal and enter: sudo killall -HUP mDNSResponder
On Linux use: sudo /etc/init.d/nscd restart and then sudo /etc/init.d/dnsmasq restart
Hopefully everyone is up and running now
This seems pretty extreme to have to do to get back on a web site, whats the deal?
just a General FYI, I still can't access prusaprinters.org
On every device you try? With all common browsers?
I have two browsers, Firefox and Microsoft on two different computers, one desktop one laptop and I can't gain access from either, I live in USA California. I get nothing but the spinning progress graphic
It's been weeks going on over a month.
