					                		Problème filament sur Spoolholder Core One+ - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/probleme-filament-sur-spoolholder-core-one/</link>
                <lastBuildDate>Tue, 17 Mar 2026 08:51:16 +0000</lastBuildDate>
                        <title>RE: Problème filament sur Spoolholder Core One+</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/probleme-filament-sur-spoolholder-core-one/#post-780736</link>
                        <pubDate>Wed, 04 Feb 2026 10:06:41 +0000</pubDate>
                        <description><![CDATA[Bonjour Hyiger,Merci pour l&#039;info]]></description>
                        <content:encoded><![CDATA[<p>Bonjour Hyiger,</p><p>Merci pour l'info </p><p> </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>eric57</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/probleme-filament-sur-spoolholder-core-one/#post-780736</guid>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/probleme-filament-sur-spoolholder-core-one/#post-780341</link>
                        <pubDate>Sat, 31 Jan 2026 18:02:02 +0000</pubDate>
                        <description><![CDATA[Posted by: @eric57 Hello,Twice in a row, with two brand new Prusa filament spools, the filament has wrapped itself around the spool holder for no apparent reason. The printer is printing in ...]]></description>
                        <content:encoded><![CDATA[<p> </p><blockquote data-userid="601551" data-postid="780291" data-mention="eric57"><div class="wpforo-post-quote-author"><strong> Posted by: @eric57 </strong></div><p>Hello,</p><p>Twice in a row, with two brand new Prusa filament spools, the filament has wrapped itself around the spool holder for no apparent reason. The printer is printing in mid-air because the filament is jammed in the spool holder, resulting in the loss of several meters of filament before I noticed. I designed a ring to prevent this; I'll see if it works with a new spool. Is there a setting I might have overlooked when setting up the machine after assembly? I never had this problem with my MK4S. I haven't had any problems so far with the spools of filament I've already started using.</p><p>Have a good day,</p><p>Eric57</p></blockquote><p>Yes, that happens a lot, especially with Prusament spools. That's why I no longer print from the side spool and only print from a drybox which is better constrained. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/probleme-filament-sur-spoolholder-core-one/#post-780341</guid>
                        <title>Problème filament sur Spoolholder Core One+</title>
                        <link>https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/probleme-filament-sur-spoolholder-core-one/#post-780291</link>
                        <pubDate>Sat, 31 Jan 2026 09:31:36 +0000</pubDate>
                        <description><![CDATA[Hello,Deux fois de suite avec deux bobines de filament Prusa neuves, le filament s&#039;est entouré autour du Spoolholder sans raison apparente. L&#039;imprimante imprime dans le vide car, le filament...]]></description>
                        <content:encoded><![CDATA[<p>Hello,</p><p>Deux fois de suite avec deux bobines de filament Prusa neuves, le filament s'est entouré autour du Spoolholder sans raison apparente. L'imprimante imprime dans le vide car, le filament est bloqué dans Dpoolholder, perte de quelques mètres de filament le temps que je m'en aperçoive, je conçu une bague pour éviter cela, à voir par la suite sur une bobine neuve. Y a t-il un paramètre que j'aurais oublié lors du réglage de machine après montage de celle-ci. Je n'ai jamais eu ce problème avec ma MK4S. Avec les bobines de filament déjà entamées aucun problème pour l'instant. </p><p>Bonne journée</p><p>Eric57  </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/english-forum-general-discussion-announcements-and-releases/probleme-filament-sur-spoolholder-core-one/#post-780291</guid>
