printables - add unlisted printers to profile
corny
(@corny)
is there an option to add printers to profile which were not listed yet by printables-team?
e.g. Flying Bear S1 or Infimech TX (which are the same printer with different name). Some other printers from Flying Bear are already listed.
Opublikowany : 24/10/2024 6:23 pm
Sembazuru
(@sembazuru)
You can get a basic start for a new custom printer in the Configuration Wizard. Note, this will be a very bare-bones profile. You'll need to go over the specs of your specific printer to enter in correct values for maximum printspeeds, accelerations, etc. Basically make sure PrusaSlicer is in Expert settings mode and go through all the settings in the printer tab filling in the specifics for your printer. You'll also need flesh out the barebones start and end (and possibly other) gcodes for your specific printer.
Either that or find in the Configuration Wizard a similar printer to your specific one as a starting point, modify those settings and save out with a custom name. For the printer(s) you mention, maybe start out with another Klipper based CoreXY printer (a Voron?).
See my (limited) designs on:
Opublikowany : 24/10/2024 7:29 pm
corny
(@corny)
RE: printables - add unlisted printers to profile
I meant in the user profile on printables.com and not in Prusaslicer.
Opublikowany : 24/10/2024 7:37 pm
MolemanTux
(@molemantux)
Here, another user with the same question.
I own a Makerparts K (renamed Kingroon KLP1 210) and wanted to add it to the profiles...
Opublikowany : 31/10/2024 11:00 pm
Sembazuru
(@sembazuru)
My apologies for the misunderstanding.
Opublikowany : 01/11/2024 8:47 pm
