Posting in forum problem ?
Plugs
(@plugs-2)
Folks can you help me I am having no luck using the Insert Image and Insert/edit media using the two icons above the text entry box. I am obviously doing something wrong. See tghis post where I put a media link in ..... MMU2S Strange events since 1.0.6 – Hardware, firmware and software help – Prusa3D Forum (prusaprinters.org)   (6 entry down from top)
Opublikowany : 12/02/2021 5:20 pm
HeneryH
(@heneryh)
RE: Posting in forum problem ?
I had problems too a while back and just gave up.  Looking to see if there is a solution here.
Opublikowany : 13/02/2021 3:47 pm
Plugs
(@plugs-2)
Think Ill chat with them on Monday as I need to post some useful stuff but useless without this
Opublikowany : 13/02/2021 3:48 pm
I always use the add media button, the bigger one.  That allows me to upload files to a media gallery on this forum. Once they are uploaded you can select one or more, choose size etc and then insert them into the message.
If I’m attaching a zip file then I use the attach file button below the text entry area but you can upload zip files to the gallery if you want to post it in several posts.
Opublikowany : 13/02/2021 6:13 pm
