New Belt Tuning Wizard
Has anyone used and had success with the new belt tuning wizard.
I had a lengthy support chat about it and when I said it was not dark enough to see the strobing light, the response was. What are you talking about?
I stopped the chat at that point and went back to the acoustic tuner.
Anyone had success with it? Tips?
RE: New Belt Tuning Wizard
I have used the Belt Tuning Wizard and it worked very well for me, in fact I hated the acoustic tuner. You actually do not see the strobing lights, you look for the belts vibrating and adjust accordingly, the Belt Tuning Wizard "strobes" the leds quicker than you can see.
It's been working fine for me since the alpha release. If it is "too dark" are your white LED's hooked up and working correctly? I compared it against the audio tuner and the differ by as much as 0.5hz. So it's quite accurate.
I guess. They are set to 100% on each line, but they are not very bright.
I know they strobe fast, but I have to still be able to see them. I'll try in a dark room and let you know.
If anything the older method was far more frustrating for me. The wizard has been a huge improvement. As with the posts above don't expect to see any flicker effect. Human eyes just don't respond quick enough for this. What you will see is an illusion where the belts appear to wobble back and forth, and you're looking for the tension that delivers the largest movement.
The gifs on Prusa's guide page are very close to what you'll see, eg:
All the best.
