Need some help remove print from glass
Im having trouble removing the white PLA from glass plate. Not even a knife can peel through the interface. Its already cooled at room temperature. What should I do in this situation. Strange that PLA should never stuck like that, what is going on here.
RE: Need some help remove print from glass
I detached it with the help of some ice
I was able to separate it
next time, try dribbling a little IPA, on the cooled build plat and letting it soak for a while, then try removing again.
or try putting the build plate complete with model, in the freezer for a while and see if differential contraction, loosens the model
