Modification of E-value G-code from slicer
Hi everyone,
Is it possible to modify the E-value of the G-code direct from the slicer?
I have to set for example this value to 150% for all the lines of the G-code. How would you do it?
I think one way is to write a script and change the g-code directly, but I don't have much experience in coding and I wonder if it is possible to do it from PrusaSlicer.
I appreciate any advice
Thank you!
RE: Modification of E-value G-code from slicer
Hi Dan, why do you want to increase E value? 150% is a large difference...
Yes. The M220 Marlin gcode command can be used to change feed rates for all axis, including E (extruder). If you turn the printer knob mid-print, is applies M220 to X, Y, Z, & E (as I understand it).
The M221 Marlin gcode command adjusts the flow percentage. This equates to the extrusion multiplier setting in your slicer. I think this might be what you're after.
Your extrusion moves need to be coordinated with your XYZ moves or you're going to throw off the proportions of your extrusions. I wouldn't do it this way at all. I'd determine what speeds, extrusion widths, and heights I want, then let the slicer with all the smarts figure out the appropriate extrusion rates. Tweak the extrusion multiplier setting if you need a bit more or less filament to be extruded on each move.
As Joan notes, this is highly questionable. If you adjust the E rate without compensating the others on normal G0/G1 moves, you're going to produce wider, thicker extrusions and are likely to make a big mess. What exactly are you trying to accomplish?
@joantabb
Hi joantabb,
because I am printing infill samples and I need to increase the line width of the infill, for example 150%, without changing the cell size.
I think the only way is acting on the E value in the g-code. If I double the E-value I obtain double of the line width if I maintain constant the line height, nozzle and speed, right?
Thanks!
@bobstro
hi thank you for the answer.
Yes the idea is to obtain at the end thicker lines for the infill, as I replied to Joan.
So if I use the M221 command in the prusa slicer can I adjust the E value for all the line of g-code?
Thanks!
Description
Set the flow percentage, which applies to all E moves added to the planner.
Usage
M221 S<percent> [T<index>]
Parameters
S<percent> |
Feedrate percentage |
[T<index>] |
Target extruder (requires multi-extruder). Default is the active extruder.
As far as I can see, this command would normally set all extrusions to the new value...
You could see if you can set the printer as a virtual multifilament printer, and set most features to extruder 1 and set extruder 2, to infill with the M221 command set against extruder 2, this may cause the effect you seem to be looking for,
@joantabb
@bobstro
I tried with the M221 command and it works for my purpose. Thank you very much!
