Implement automatic shutdown after Print.
Strona 2 / 2
Escrich
(@escrich)
RE: Implement automatic shutdown after Print.
And this is, till now, my safest system to switch off the printer, everything gcode controlled
https://github.com/Escrich . https://t.me/escrich . https://www.tiktok.com/@josemescrich
Opublikowany : 13/11/2024 5:31 pm
Walter Layher
(@walter-layher)
I think I can see a Raspberry Pi in your photo. This can control a relais via its GPIO. I am sure the control software running on the Pi (Klipper?) can take care of that.
Opublikowany : 13/11/2024 5:32 pm
Escrich
(@escrich)
Yes, may be this is not very good for you, the next one has his own intelligent microcontrollers, watchdogs, , security messages between devices, and timeouts no longer than two seconds, safety exists, I was last 34 years working on that
Opublikowany : 13/11/2024 5:35 pm
Walter Layher
(@walter-layher)
I thought we were talking about controlling a Prusa MK3 or MK4, did not expect you were not. 🙂
Opublikowany : 13/11/2024 5:40 pm
1 ludzie polubili
Escrich
(@escrich)
Definitively this is not the right forum for that.
Good luck!
Bye!
Opublikowany : 13/11/2024 5:46 pm
_KaszpiR_
(@_kaszpir_)
Another option is to poll printer status over PrusaLink API to see what it does and react based on that.
Another option is to listen to the syslog messages the printer generated and also react on that but this may be a bit more complicated to implement ( for example convert syslog messages to mqtt events).
Opublikowany : 14/11/2024 7:48 am
1 ludzie polubili
Walter Layher
(@walter-layher)
If you have Home Assistant, there is an integration for PrusaLink. You can then create automations there like for all the other things in Home Assistant.
Opublikowany : 14/11/2024 8:36 am
Escrich
(@escrich)
I have the control based on API behaviour working now
Posted by: @_kaszpir_
Opublikowany : 08/09/2025 9:22 pm
Tim
 Tim
(@tim-21)
I'd just like the dang firmware to return to the home screen after a print rather than the silly "Do you want to reprint?" screen, which is made even worse by reprint being the default. How often do normal users reprint the same thing over and over again that this UI setup makes any sense.  I can see it for a factory setting, where you have 50 printers running making parts, but that begs the case of having a selectable FARM MODE that selects preferences for that use case.
Opublikowany : 08/09/2025 11:50 pm
Strona 2 / 2
