Ikea Lack Enclosure - Sovol SV01
xenon2008
(@xenon2008)
Hello together!
I am new here and found that here many People has build an Enclosure for there Prusa Printers or other Printers.
I have a Sovol SV01, and asked me if somebody from here did already build such an Enclosure for this Sovol SV01 Printer?
Because one Ikea Lack is to low... And i also did not know if it will fit into the deepth?
Sorry for my Bad English i am not very Good in, because i am a German/Austrian User, with terrible English Skills.
Maybe somebody can help me?
Veröffentlicht : 13/01/2021 5:56 pm
RE: Ikea Lack Enclosure - Sovol SV01
I think @towelrg has a Sovol, though I have no ide if he's using an enclosure. The bed dimensions of the Sovol SV01 are a bit smaller than the Prusa Mk3, so the measurements should be close. It looks like a 24x24inch (70x70cm) enclosure will suffice. Most enclosures made with the Lack tables are using 2-3 tables stacked with brackets holding them together.
Veröffentlicht : 13/01/2021 10:59 pm
John Doe
(@john-doe-3)
I got plexiglas 1m x 1m from hobby market, cut by hand to 44cm x 50 cm , so I had to raise the lack foot by 6 cm. There are some models already for it.
Like: Ikea Lack 90mm extension | PrusaPrinters
Veröffentlicht : 14/01/2021 6:53 am
xenon2008
(@xenon2008)
Posted by: @bobstro
smaller? the Bed from the SV01 is 300x255mm
Veröffentlicht : 14/01/2021 2:13 pm
towlerg
(@towlerg)
Lack clearance height is approx 400mm, SV01 is approx 500mm. Footprint is about 500x540 (490x540 if LCD repositioned). Given that all the electronics are in the base, you probably want to get some airflow in there and seal off the underside of the base from the rest of the enclosure (draft excluder etc)
I don't have an enclosure, probably should.
Veröffentlicht : 14/01/2021 2:30 pm
PrusaPrinters profile
(@prusaprinters-profile)
Servus kleiner Tipp:
https://forum.prusa3d.com/forum/deutsches-forum-allgemeine-diskussion-ankuendigungen-und-veroeffentlichungen/
Grüsse aus Wien.
Veröffentlicht : 15/01/2021 9:09 pm
