I would like to either reference the desired print/printer/filament settings in the master ini file
I would like to either reference the desired print/printer/filament settings in the master ini file (PrusaResearch.ini) from a local ini file, or extract all the settings into individual files like they were before PS version 1.40. The reason I want to do this is because I use make to manage print projects, so I'm using PS in command-line mode. With the older versions of PS I could use a command with --load instructions for the chosen individual master print, printer, and filament files, along with the local ini file that contains just whatever I want to change from the default settings. The newer versions of the slicer, with a consolidated master ini file, have made that a little more difficult.
Either approach with work, but so far I've been unable to get a local ini file to reference any settings in the global ini file. So I'm at the point of writing something to extract individual files, but thought I would ask here first, in case someone else has already solved this.
RE: I would like to either reference the desired print/printer/filament settings in the master ini file
I haven't tried this yet, myself, but I wonder if the new-ish (as of 2.8.0 alpha5) offline profile repository system will allow you to create your own "official" profiles. You may be able to download the files and load them as local files and customize the ini file to your heart's content.
See my (limited) designs on:
