Humidity Control For Filament Storage - How Tight Does a Container Have to Be?
Page 2 / 2
Conrad
(@conrad-2)
Random thoughts, some based on decades of experience in the scientific world, some total WAG!
I've been using SwitchBot IP65 Indoor Outdoor Hygrometer Thermometer Wireless 3Packs and they seem to work well. Accuracy is good compared to several other references I've got. They can data log for 68 days before rollover and I can check the temp and humidity graph on my phone Bluetooth anytime I feel the need.
I think most people's silica gel desiccant isn't as dry as they think. You have to bake it in an oven just below where the envelopes are damaged to drive the water out. I thought it would be nice to dry it in a filament dryer, but a recent video showed that was near worthless. They also used a microwave, but that method seems labor intensive. I use a small oven. In another life I used 4A Zeolite as a lab desiccant and the stuff will work wonders at low RH, but you have to bake it seriously hot, about 300C for several hours, to get it dry, and then prevent readsorption while it cools. At that level of dryness, you should avoid skin contact.
Inexpensive consumer dehumidifiers are crap. If they last two years you're doing well. Maybe 3-4 if you get a good one, but there's no way to tell if it's a good one. I use one in my hobby room and it will keep the room at about 45% RH during the summer. In the winter, without it, the room runs about 36% RH.
You probably can't build an airtight box. Well, maybe if you're a welder, have a lot of stainless-steel plate and access to a Veeco helium leak detector. The best box you can build will breathe as the barometric pressure rises and falls. And you certainly have to open it every now and then. That means using a decently dried desiccant and changing it out on a regular basic, based on a humidity sensor. It's a process that you just have to keep up with.
Too soon for a review, but I recently got the Creality SpacePi X4 and it seems to work quite well.
Posted : 21/02/2026 5:32 pm
RE: Humidity Control For Filament Storage - How Tight Does a Container Have to Be?
Posted by: @cwbullet
In my experience, that is low enough for 99% of filament I use.
Except for PA6 and PPA, I agree.
Posted : 21/02/2026 5:33 pm
Robin_13
(@robin_13)
Thank you for this information.  I may not try the experiment after reading this.  I have looked at how they work and that may be part of the issue.  They are not designed to keep things dry but to lower high humidity.  I may purchase one and see if it can be modified to work for my (our) purpose.
Posted by: @mnentwig
Note, an electric dehumidifier (I got a small one for my home after the guitar complained in autumn) has an efficiency curve that drops significantly below 50 % RH and lower temperatures. Under tropical test conditions it'll collect buckets per day - per the advertised performance. But in an already fairly dry and cool (!) room don't be surprised to find only a few drops of collected water after hours or even none at all.
I originally planned to keep my MMU loaded permanently so the printer is always ready. But with 50 % RH I but moved away from that, unload it directly after printing or at the end of the day.
Posted : 28/02/2026 4:18 am
Robin_13
(@robin_13)
Molecular sieve desiccants are a world on their own.  Activated alumina is used in some molecular sieves and the drying procedure is similar to what you claim for 4A Zeolite.  I weigh my desiccant before putting it into the convection toaster oven for 2.5 to 3.5 hours, then put it into an old pressure cooker till it cools.  Minimizes the amount of water it can absorb from the air.  I then weigh it again to see what the mass change is.
Reading about 4A Zeolite, it looks good for some filaments.
Posted : 28/02/2026 4:38 am
Posted by: @hyiger
Cheap hydrometers bottom out at 10% RH.
<nitpick> The correct term is "hygrometer" when referring to an instrument that measures the relative humidity of air. "Hydrometers" also exist but are completely different devices; they measure the density of a liquid via buoyancy. </nitpick>
Posted : 01/03/2026 6:36 am
Posted by: @jurgen-7
Posted by: @hyiger
<shrug emoji> noted
Posted : 01/03/2026 6:48 am
UjinDesign
(@ujindesign)
New filament in the bag, is NOT dry in many cases and users need to assume that they need to dry it before use.
I've heard this alot but I've actually never experienced it myself. Maybe it's manufacturer-specific? I purchase almost all my filament from add:north (made in Sweden, relatively expensive).
Posted : 01/03/2026 8:53 am
Posted by: @ujindesign
Probably depends on where and when it was made. That is the RH of the factory when it was package. Most filaments I've purchased from Prusa that are hydroscope, PC being one example, have to go in the dryer after removing from a sealed bag.
Posted : 01/03/2026 4:14 pm
Page 2 / 2
