How many hours can an MK3S printer print?
Utenti
I do regular maintenance.  My Mk3 that was upgraded to a MK3S and MK3S+ has over 20,000 hours of print time.  It has been printing 55% of the time I have had it which is pretty good.  It has had very limited down time for repairs.  I think the longest time I took off from printing was an 11 day vacation.
How long do you think it can keep going?
Oh, by the way, it still has the original bearings.
Postato : 04/10/2022 2:42 pm
AnnieR
(@annier)
RE: How many hours can an MK3S printer print?
No clue but you sure got your money's worth!
Postato : 04/10/2022 3:31 pm
R&D
 R&D
(@rd)
How many licks does it take to get to the Tootsie Roll center of a Tootsie pop?
The world may never know.
Postato : 04/10/2022 3:43 pm
jsw
 jsw
(@jsw)
Ok, Doctor, here's the Big Burning Question.
On those 'original bearings', did you install them as they came from Prusa, or did you wash them out with solvent and totally re-grease them, or did you maybe add additional lubricant when assembling?
Postato : 04/10/2022 4:25 pm
One of my MK3 is already about 7000 hours in operation and the bearings are still almost like new. However, I have sintered, oil-soaked bearings installed, which are almost indestructible and significantly reduce the operating noise.
I think that 50000 hours is no problem, although you have to calculate with the fact that wear parts have to be replaced every now and then.
wbr,
Karl
Postato : 04/10/2022 5:19 pm
jsw
 jsw
(@jsw)
I haven't checked the stats for some time, but on the I3 I currently show 869 days, 23 hours, and 14 minutes.
This comes out to 20,879 hours and change.
14565.57 meters of filament.
I didn't realize it was that high, but I can believe it, since I was printing very heavily through the height of the pandemic.
And, for the record, when I assembled the kit, I followed TFM exactly and installed the bearings as they came, without any additional lube.  As stated in TFM, I give the rods a couple of drops of lightweight synthetic machine oil every so often, and I rub some Superlube on the rods every so many so-oftens.  No bearing play nor bearing noise.
I admit that it needs a good blow-out and cleaning, and I intend to as soon as I anticipate a few days of slack time on it and free time on my part.
Postato : 04/10/2022 8:32 pm
Yeash this thread just prompted me to check the statistics as I haven't for ages.
367d 10h 21m and 15041.43 meters.
Its a Mk3 (non S) same bearings from day one, although I did clean them and repack before building initially.  I've also rebuilt the extruder in the 4+ years I've had it and I did clean and repack the X axis bearings when I did that but the Y and Z haven't been done in that time. I check smoothness semi regularly and only apply a bit of oil if needed.  Which hasn't actually been that often really.  Probably once every 6-9 months.  No excessive noise.
Postato : 04/10/2022 8:50 pm
Utenti
That is a great question.  I have no idea.  This one was one of the first off the line and was assembled by Prusa.  It is starting to increased noise and might need a more extended period of down time to replace some bearings.
Posted by: @jsw
Postato : 05/10/2022 12:55 am
AnnieR
(@annier)
Okay I checked. Lightweight here! Comes out to 770 hours.
Postato : 08/10/2022 4:37 pm
Eric E
(@eric-e)
Utenti
Posted by: @karl-herbert
<snip>However, I have sintered, oil-soaked bearings installed, which are almost indestructible and significantly reduce the operating noise.
</snip>
wbr,
Karl
Can you share clues on the bearings?
Don’t trust forum advice.
Postato : 08/10/2022 5:17 pm
Posted by: @eric-e
wbr,
Karl
https://www.printables.com/de/model/51755-prusa-mk3s-mini-y-achse-gehause-fur-sinterbronzela
wbr,
Karl
Postato : 08/10/2022 9:28 pm
jsw hanno apprezzato
Posted by: @annier
Well, then successful printing for additional 49230 hours 👍
wbr,
Karl
Postato : 08/10/2022 9:44 pm
jsw
 jsw
(@jsw)
So far I have not noticed any significant increase in mechanical noise level when printing, and there is certainly no visible scoring of the stainless rods.
I do lubricate them regularly, and I've followed TFM regarding NOT lubricating the trapezoidal nuts.
As I've said, it's overdue for a good PM, so when I have some time this fall I'll take it down and give it a good cleaning and lube, lube the extruder gears, blow out the whole thing, tune the belts to a low D, and probably re-seat the cabling, which I have never done, I admit.
If/when I notice more noise and/or obvious play in the mechanism I may try something like Karl's mod for some of the high-tech bearings.
Postato : 08/10/2022 9:58 pm
Emi Lia
(@emi-lia)
I think that 50000 hours is no problem, although you have to increase or decrease the hours
Postato : 14/10/2022 11:25 am
