Hotend fan not spinnig after slightly touching it
Hello,
I accidentally touched the hotend fan when it was running (I have a MINI+). It stopped for a second and resume running for a while. Now it cannot start again. It seems extremely fragile just to stop spinning because I slightly touched it a second.
Is there anything I can do to fix it?
Thanks,
Opublikowany : 27/07/2021 5:34 pm
Suggestion
Did you try turning you printer off and on again?
Opublikowany : 27/07/2021 5:52 pm
Check for blade obstructions
Make sure the fan blades aren't stuck or crooked. A bit of debris can block them.
Opublikowany : 27/07/2021 5:57 pm
