Hot End Gooing Up With PETG
DoubleTs
(@doublets)
It seems whenever I print PETG the hot slowly goos up, especially on the first layer.  I think it has cost me a couple of prints in a bad way.  The last print had a good amount of material on the hot end, but didn't cause an issue.  I've also been know to pause the print and pull it off with pliers.  Does anyone have any idea what may be causing this?  Does it need a new nozzle?
Thank you
Posted : 12/03/2026 3:30 am
Artur5
(@artur5)
RE: Hot End Gooing Up With PETG
Before replacing the nozzle try first drying the filament. PETG isn't exactly a friendly customer if it's wet. As you see, it likes sticking to the nozzle, dropping blobs and zits everywhere and all kind of trouble, Of course, some brands of PETG filaments are worse than others in this regard. You should tell us the model of printer and the brand/color of this filament. That will help us to diagnose the problem.
BTW is it a regular nozzle or a HF one ?
Posted : 12/03/2026 9:24 am
DoubleTs
(@doublets)
I have tried drying it to no avail, but it still happens straight out of the dryer. Believe it or not it is my original nozzle that came with my Mk3, before I upgraded it to Mk3.5. It doesn't have a ton of hours, but it is by no means new.  I have no issues with PLA and my X1C doesn't have this issue with the same spool.
Posted : 13/03/2026 1:05 am
Artur5
(@artur5)
If I were you, I'd change the nozzle. The one that you're using must be well past prime by now. Anyway, with PETG is very important to have a spot-on Z-offset on the first layer and a perfectly clean bed. If Z it's too high, with PLA you still can manage more or less well, but PETG is merciless, even dry. It tends to stick to the tip of the nozzle instead of the printing plate, specially if the bed isn't clean enough, and this is where the trouble starts. Which brand/color of PETG are we talking about ?.
This post was modified 2 months ago 2 times by Artur5
Posted : 13/03/2026 10:00 pm
DoubleTs
(@doublets)
Sorry for the delay, but I just changed the nozzle and got a chance to test it. It is working much better now, but it did get stringy near the end of the print, my guess is damp PETG.
Thank you
Posted : 07/05/2026 1:08 am
Posted by: @doublets
Thank you
I don’t consider PETG to be beginner friendly. It has to be kept dry and it has a tendency to clump on the nozzle. I often clean the nozzle between prints with a brass brush. Also, I don’t print PETG anymore and use PCTG instead. It’s better. Easier to store and doesn’t string.
Posted : 09/05/2026 5:53 pm
Onno
 Onno
(@onno)
Like others have said already, you need to dry your filament. But what also helps is to use Slice Engineering's Plastic Repellent Paint™ Also sold by Bondtech in the EU
This post was modified 14 hours ago by Onno
Posted : 09/05/2026 7:14 pm
Artur5
(@artur5)
I've been using that repellent paint for a couple of years. It helps, but it doesn't performs miracles. PETG needs to kept dry or it will stick to the nozzle, regardless of  the paint, Also, you must renew the paint coat pretty often if you use a brash brush to remove filament residues.  As hyiger, I started to use PCTG instead of PETG. Similar filaments but PCTG is more user friendly in several aspects. Interlayer adhesion is not great, but so it's PETG's.
Posted : 10/05/2026 8:20 am
