Help With Articulated Shark With Movable Jaw
I am trying to print this, the version with the movable jaw.
https://www.printables.com/model/178032-articulated-shark
Everything turns out great except the top teeth. Even when I try supports there are still issues with the teeth. I am new to using supports. Can anyone provide advice on how to set it up so the top teeth print perfect? I tried painting on supports, painted only the top teeth.
Thank you,
Dan
Opublikowany : 16/05/2026 1:13 pm
RE: Help With Articulated Shark With Movable Jaw
Have you checked all the way at the bottom of the “User Print Files” folder? There's a file at the very bottom that has support.
Opublikowany : 16/05/2026 1:44 pm
