GraphQL moved?
before I was able to query some stats from the Prusa site via:
- platform: rest
resource: https://www.prusaprinters.org/graphql/
method: POST
payload: '{"operationName":"UserProfileSocial","variables":{"id":"101152"},"query":"query UserProfileSocial($id: ID!) {\n user(id: $id) {\n ...AvatarUserFragment\n hashId\n publicUsername\n email\n place\n offersPrintOnDemand\n offersTechSupport\n offersTechService\n offersShowAndTell\n isFollowedByMe\n downloadCount\n printsCount\n eduProjectsCount\n userGcodesCount\n followersCount\n followingCount\n makesCount\n collectionsCount\n eventsCount\n rating\n isPublicSpace\n publicSpaceUrl\n isTeacher\n promotionLinks {\n status\n url\n __typename\n }\n badgesProfileLevel {\n profileLevel\n __typename\n }\n badgesSelection {\n order\n userBadge {\n id\n name\n description\n levelsCount\n currentBadgeDisplayName\n currentBadgeLevel {\n name\n image\n __typename\n }\n __typename\n }\n __typename\n }\n coordinates {\n lat\n lng\n __typename\n }\n locationSharing\n bio\n donationLinks {\n id\n title\n url\n __typename\n }\n socialLinks {\n id\n socialType\n url\n __typename\n }\n printers {\n id\n name\n __typename\n }\n languages {\n id\n name\n __typename\n }\n techService {\n techServiceBio\n techServicePrinters {\n id\n name\n __typename\n }\n techServiceRatingAvg\n techServiceRatingCount\n __typename\n }\n __typename\n }\n}\n\nfragment AvatarUserFragment on UserType {\n id\n publicUsername\n avatarFilePath\n slug\n badgesProfileLevel {\n profileLevel\n __typename\n }\n __typename\n}\n"}'
value_template: "{{ value_json.data.user.downloadCount }}"
headers:
Content-Type: application/json
But that does not seem possible anymore. I tried to change the obvious "resource: https://www.prusaprinters.org/graphql /" to "resource: https://www.printables.com/graphql /" but that did not work either ...
Opublikowany : 10/10/2022 5:03 pm
Topic starter
answered:
RE: GraphQL moved?
Prusa team replied ... the solution is to replace: “ https://www.prusaprinters.org/graphql/”
… with the current API location: “ https://api.printables.com/graphql/”
Tested and works again for me!
Opublikowany : 11/10/2022 12:15 pm
RE: GraphQL moved?
Ensure that the API doesn't require authentication, or if it does, make sure you're including the necessary headers, such as an API key or bearer token. collegebrawls
Opublikowany : 02/09/2024 5:41 pm
