good CNC and 3d Print project?
i am trying to build a CNC machine do you have any projects that you have worked on and are good or even heard of that are good?
i have come across a few (below), some are customer size, where you just get a larger rod size to make it wider, others seem like you can use which ever router tool you have, and one where you can also attach a hot end to and uses as a 3d printer (vid below of this)
Also some things i was considering when looking into CNC projects, feel free to add in your own points that may be useful
1) do you know of any CNC project which are scalable as an you can have small or large cutting/milling area ?
2) can can also fit a hot end on it?
3) is adjustable and takes many different size router tool?
4) price is also important but depends on the project?
PrintNC - open sources
 https://threedesign.store/
INDSYS - open source
 https://indystry.cc/
MPCNC
 https://www.v1engineering.com/
RE: good CNC and 3d Print project?
I'll be watching to see what responses are posted. I have a CNC machine and a Prusa MINI 3D printer.
@johndoe-4
Interesting for processing larger objects and light materials or for plotting, etc.
