Gcode conditional syntax
Here is a gcode bit I got from the forum:
M900 K{if printer_notes=~/.*PRINTER_MODEL_MINI.*/ and nozzle_diameter[0]==0.6}0.12{...
I don't understand the =~/ part. The documentation I could find about gcode comparisons mentions that anything in exprtk should work, and that includes singe equal as equality comparison. The tilde ~ in that context and position doesn't make sense to me. Is it a NOT? Is it some kind of indication that the following is a regex? Where is this documented?
RE: Gcode conditional syntax
That's PERL syntax as used in the original Slic3r, but it's similar to many other programming languages. =~ means "contains" and is used to match if a pattern is present in a string. The slashes (/) delimit the regular expression being matched. The PrusaSlicer regular expressions get pretty funky as they grow longer and longer. Unless you're sharing this profile with others, it is easiest to just plug in the values that you want to use with your printer and avoid the regular expressions.
M900 K ... my favorite command. Linear advance level. For water proof prints - those that I don't want to fill with water when I send them down 190 feet of salt water - I know this syntax, but I didn't ever guess that it meant "contains". Thank you. Even easier to parse.
For those who worry about linear advance, there is an override in the main settings - you can disable linear advance there. I think. At least I told it to. Saves me having to fuss with M900 K0;
[...] For those who worry about linear advance, there is an override in the main settings - you can disable linear advance there. I think. At least I told it to. Saves me having to fuss with M900 K0;
I'm not aware of a PrusaSlicer setting that will disable linear advance settings inserted in custom filament gcode. These lines are just inserted raw at the start of a print. Open up a gcode file in a text editor and verify that the M900 Kxx line is not present.
@bobstro
Thanks! I'm a programmer, yet I've managed to almost never use Perl. I'm surprised that the fact the Slic3r (may) use Perl here did not pop up in my searches! Here to hoping that the next person searching for it will find this thread.
