Friction Coefficient and Hydroscopic Tendencies
gcarmich
(@gcarmich)
Is there a material reference table that includes coefficient of friction and hydroscopic nature of filament materials?
Postato : 29/01/2025 1:54 am
Bruce Lucas
(@bruce-lucas)
RE: Friction Coefficient and Hydroscopic Tendencies
ChatGPT
Here are the approximate coefficients of friction (CoF) for some common 3D printing filaments:
1. PLA (Polylactic Acid):
• Static CoF: ~0.35–0.40
• Dynamic CoF: ~0.30–0.35
• Notes: PLA has a relatively smooth surface and low wear resistance, making it prone to reduced friction over time.
2. ABS (Acrylonitrile Butadiene Styrene):
• Static CoF: ~0.40–0.50
• Dynamic CoF: ~0.35–0.45
• Notes: ABS is slightly rougher than PLA, with better wear resistance and a moderate coefficient of friction.
3. PETG (Polyethylene Terephthalate Glycol):
• Static CoF: ~0.30–0.40
• Dynamic CoF: ~0.25–0.35
• Notes: PETG is known for its smoothness and excellent wear resistance, making it suitable for low-friction applications.
4. Nylon (Polyamide):
• Static CoF: ~0.15–0.25
• Dynamic CoF: ~0.10–0.20
• Notes: Nylon has a very low coefficient of friction, making it ideal for gears, bushings, and other moving parts.
5. TPU/TPE (Thermoplastic Polyurethane/Elastomer):
• Static CoF: ~0.60–1.0 (depending on flexibility and surface texture)
• Dynamic CoF: ~0.50–0.90
• Notes: TPU has a high coefficient of friction due to its rubber-like surface, making it excellent for grip-related applications.
6. PC (Polycarbonate):
• Static CoF: ~0.30–0.35
• Dynamic CoF: ~0.25–0.30
• Notes: PC is a strong and durable material with moderate friction and good wear resistance.
7. POM (Polyoxymethylene, also known as Delrin):
• Static CoF: ~0.10–0.20
• Dynamic CoF: ~0.05–0.15
• Notes: POM has an extremely low coefficient of friction and is commonly used in mechanical parts requiring low friction.
8. Carbon Fiber Reinforced Filaments (PLA, ABS, Nylon, etc.):
• Static CoF: ~0.25–0.35
• Dynamic CoF: ~0.20–0.30
• Notes: Adding carbon fiber reduces friction and increases wear resistance compared to the base material.
Considerations:
• The CoF depends on the surface finish of the printed part, layer lines, and environmental conditions (e.g., humidity, temperature).
• For precise applications, post-processing like sanding or applying lubricants can alter the coefficient of friction.
Postato : 29/01/2025 2:03 am
Bruce Lucas
(@bruce-lucas)
DeepSeek
The coefficient of friction (COF) is an important property for 3D printer filaments, especially when considering how the filament interacts with the printer's extruder, guide tubes, and build surface. Below are the approximate coefficients of friction for some common 3D printer filaments:
Static COF: ~0.3–0.4
Dynamic COF: ~0.2–0.3
PLA has a relatively low coefficient of friction, making it easy to print with and less likely to cause feeding issues.
Static COF: ~0.4–0.5
Dynamic COF: ~0.3–0.4
ABS has a slightly higher COF compared to PLA, which can sometimes lead to more wear on extruder components.
PETG has a similar COF to PLA but can be slightly more prone to sticking in Bowden tubes or extruders if not properly lubricated.
4. TPU/TPE (Thermoplastic Polyurethane/Polyether)
Static COF: ~0.5–0.7
Dynamic COF: ~0.4–0.6
TPU and TPE filaments have a higher COF due to their flexible and sticky nature, which can cause feeding issues in Bowden setups.
5. Nylon
Static COF: ~0.2–0.3
Dynamic COF: ~0.1–0.2
Nylon has a very low COF, which makes it slippery and sometimes challenging to feed through extruders without proper tension.
6. Polycarbonate (PC)
Polycarbonate has a moderate COF but can be abrasive over time, leading to wear on extruder components.
7. ASA (Acrylonitrile Styrene Acrylate)
ASA has a similar COF to ABS, making it relatively easy to print with but slightly more abrasive.
8. PVA (Polyvinyl Alcohol)
PVA has a low COF but is highly sensitive to moisture, which can affect its performance during printing.
9. HIPS (High Impact Polystyrene)
HIPS has a COF similar to ABS and is often used as a support material.
10. PP (Polypropylene)
PP has a very low COF, making it slippery and challenging to print without proper adhesion to the build plate.
Notes:
The COF can vary depending on surface finish, temperature, and humidity.
Lubrication or coatings (e.g., PTFE tubes) can reduce friction in Bowden setups.
Higher COF materials may require stronger extruders or direct drive systems to avoid feeding issues.
If you're experiencing friction-related issues, consider adjusting your printer's settings, using lubricants, or upgrading to components designed for high-friction filaments.
Postato : 29/01/2025 2:05 am
MrNerdHair
(@mrnerdhair)
Utenti
Why would you trust numbers made up by a computer when you wouldn't trust numbers made up by a human?
The CoF of printed plastics can be fairly nonlinear. (See, for example, some actual research.) Note, for example, that the CoF of PETG drops significantly as the load increases.
Questo post è stato modificato 2 months fa da MrNerdHair
Postato : 24/10/2025 7:55 am
