Food-safe filament for parts in oven
Seite 1 / 2
sopis
(@sopis)
Hello All
We have an older model of Baumatic oven and there are plastic holders on the door that actually hold the glass to the oven door.
These plastic holders have now broken and the glass does not hold on the door, so we cannot use the oven as we risk the glass would fall and break.
I am waiting for a local service center to obtain these parts, however they seem to be completely out of stock and not available anymore - we have now been waiting for several months.
I am thinking of designing and printing these parts, however I have no idea what is the best material to use here.
It must be high-temp resistant, food-safe and slightly flexible (because of how it is installed and how the glass is mounted).
Any recommendations on the material please?
This is the part in question: SPARE PART
Thanks in advance!!!
Veröffentlicht : 14/08/2024 8:46 am
What temperatures must this withstand?  If it gets too hot for thermoplastics you may do better priting a mould for casting a resin part.
Veröffentlicht : 14/08/2024 1:09 pm
3Delight
(@3delight)
Moderator Moderator
RE: Food-safe filament for parts in oven
Technically, 3D printed parts are never food safe as they are made up of layers with tiny gaps in them where bacteria can live and grow.  But you'll need to do some heavy research to find what types of plastic are safe for use in an oven as, even though the part is unlikely to come into contact with the food, it may release particulates into the air which can settle on the food.  I doubt any filament based plastics will be of any use because of the temperatures they will endure in an oven.  I suspect in the long run you'll be better off searching for a retailer with spare parts in stock! (Ebay?)
Veröffentlicht : 14/08/2024 4:19 pm
sopis
(@sopis)
very true, I am aware of all what you describe and yes, these parts will never get in touch with food...actually, these parts won't even get close to the food as they are between the metal door and the outside glass...
bottom line, even if it is not extra food-safe, is there any material that can withstand temperatures close to 300 C?
thanks for your reply!
Veröffentlicht : 14/08/2024 4:54 pm
sopis
(@sopis)
what about printing this in resin? do you think it would be a better option? I also own a resin printer
Veröffentlicht : 14/08/2024 4:57 pm
The only high temperature resistant printing resin I know of is Phrozen TR300 but I don't think it goes that high.  There are several specialist epoxies that would take the heat if you printed a mould...
Veröffentlicht : 14/08/2024 5:27 pm
JP Guitars
(@jp-guitars)
Posted by: @sopis
If you think it through, any plastic that can cope with 300C will not be meltable in a 3D printer
Veröffentlicht : 14/08/2024 5:44 pm
JimB
 JimB
(@jimb)
If it is a self cleaning oven, they can get a lot hotter: well over 500C.
Veröffentlicht : 14/08/2024 5:51 pm
sopis
(@sopis)
damn that is so true 😀 I did not think my question through...well I am getting clueless as what to do :/ worst case, I can get some metal pieces and shape them accordingly...let's see...
thanks all for your replies
Veröffentlicht : 14/08/2024 6:34 pm
modeler
(@modeler)
Mitglied
The Essential Guide to Food Safe 3D Printing | Formlabs
https://formlabs.com/blog/guide-to-food-safe-3d-printing/
Veröffentlicht : 14/08/2024 7:19 pm
Eds_3D_Odyssey
(@eds_3d_odyssey)
Have you thought about buying a used one and using it for parts?
https://www.printables.com/@Eds3dOdyssey
Veröffentlicht : 14/08/2024 8:31 pm
You can prototype - get the shape right - in plastic then send the file(s) to a metal-printing service for production.
Veröffentlicht : 15/08/2024 3:29 am
efvee
(@efvee)
Print a mould and cast the model in 2 component silicone rubber. This is a thermohardener and it is happy in 200+degC.
Veröffentlicht : 15/08/2024 2:42 pm
sonic bionic
(@sonic-bionic)
Hi there, have you used the TR300 Ultra-High Temp Resin? Do you have a Profile for the SL1S you would be willing to share?
Thanks!
Veröffentlicht : 29/09/2024 7:46 pm
Berezny
(@berezny)
Mitglied
Typically around 70-80°C (158-176°F) for continuous use but can withstand higher temperatures for short periods. PETG is generally considered food-safe, especially if sourced from reputable manufacturers.
Veröffentlicht : 30/09/2024 1:15 pm
Darryll Truchan
(@darryll-truchan)
Posted by: @3delight
This has been proven wrong.   Anywhere bacteria can get. So can warm soapy water.
https://lt728843.wixsite.com/maskrelief/post/the-final-say-in-food-safe-3d-printing
Veröffentlicht : 06/10/2024 8:05 am
Interesting link, leading to:
https://www.researchgate.net/publication/375373442_The_Impact_of_Sanitation_Methods_of_3D-printed_Parts_for_Food_and_Medical_Applications
I may ask some students to replicate it.
Veröffentlicht : 06/10/2024 12:01 pm
lelaasaim
(@lelaasaim)
Mitglied
Honestly, printing a part for the inside of an oven is extremely risky because even high-temp filaments like PC or PEI can soften or release toxic fumes at those temperatures. Your best bet is to use your 3D print as a mold to cast the part in food-grade, high-temperature silicone which can actually handle the heat and provide the flexibility you need...
Veröffentlicht : 18/04/2026 2:11 pm
Public username (required)
(@public-username-required)
There is a special glue for oven doors. It's a high temperature silicone glue for glass. "oven door glue" in your favourite search engine will find something.
Veröffentlicht : 19/04/2026 4:19 pm
Conrad
(@conrad-2)
Casting is a good way to go but that's such a trivial part to machine. Just go to a local machine shop, or even a hobbyist, with the part and ask for half a dozen in Delrin or aluminum. That doesn't look like something that gets exposed to the full oven temperature. I'm the biggest fan of 3D printing but some things are just better machined.
Veröffentlicht : 19/04/2026 4:58 pm
Seite 1 / 2
