fixing errors
Strona 2 / 3
jsw
 jsw
(@jsw)
I do not have the Mini, but I have found that many files downloaded from the 'usual suspect' 3d print sites are corrupt, as in mesh errors, often times many of them in a file.
I've also had very poor luck trying to run somebody else's pre-sliced .gcode files.  More often than not there are differences between what parameters the author used to slice and what my machine performs best with.
I've found very little difference, if any, in the Z height performance between PLA and PETg.  (And ABS and PC Blend as well.)
What I have found, however, is that Cura (slicer) is often times far more forgiving on a wonky .stl/.obj file than is PrusaSlicer.
Opublikowany : 27/06/2022 6:51 am
RE: fixing errors
The conventional wisdom is that PETG doesn't "like" to be squished as much as PLA. But like @jsw, in my hands I see little difference, perhaps because I tend to err on the side of less squish when I calibrate Live Z for PLA.
Opublikowany : 27/06/2022 10:31 am
Robin
(@robin)
RE: fixing errors
I assume petg and pla need different z height
Not necessarily, but the definitely need different gcodes.
Opublikowany : 27/06/2022 1:04 pm
1 ludzie polubili
mnosek
(@mnosek)
RE: fixing errors
should I be using the textured plate for petg?
Opublikowany : 27/06/2022 7:54 pm
RE: fixing errors
Check out Prusa's Material Guide: https://help.prusa3d.com/materials.
I use the satin sheets for everything. Best thing since sliced bread.
Opublikowany : 27/06/2022 7:57 pm
jsw
 jsw
(@jsw)
RE: fixing errors
Posted by: @mnosek
If you want to.
I've had great luck with PETg on both the smooth and textured build plates.
Opublikowany : 27/06/2022 8:18 pm
jsw
 jsw
(@jsw)
RE: fixing errors
Posted by: @fuchsr
I get a 404 on that link.
Opublikowany : 27/06/2022 8:19 pm
mnosek
(@mnosek)
RE: fixing errors
I will have to get one I have the textured and original steel
Fuchsr accidentally added a full stop to the link from the looks of it https://help.prusa3d.com/materials#_ga=2.226403676.798294972.1656347405-2003382291.1648659050
Posted by: @jsw
Posted by: @fuchsr
Opublikowany : 27/06/2022 8:50 pm
RE: fixing errors
It's actually a "feature" of the forum software 😡 When you type a period after a URL to finish the sentence, on auto converting the URL to a clickable link in its infinite wisdom it includes the period in the link...
Opublikowany : 27/06/2022 10:19 pm
jsw
 jsw
(@jsw)
RE: fixing errors
I guess I should have noticed that.  I just saw the 404.
I have not looked at that since they added the satin sheet.  I'm kinda surprised that they do not have the 'with glue stick' admonition for the satin sheet with ABS.
I would be afraid of pulling the coating right off of the plate with a large-footprint ABS print with no release agent.
Opublikowany : 27/06/2022 10:27 pm
mnosek
(@mnosek)
RE: fixing errors
took temp up and moved the z height even closer and it seems to be working. will order the satin sheet and try it though. thank you everyone for your help
Opublikowany : 27/06/2022 10:49 pm
Swiss_Cheese
(@swiss_cheese)
RE: fixing errors
I just thought I was going to have to wait till the 3rd quarter to see the page.
The Filament Whisperer
Opublikowany : 28/06/2022 12:42 am
mnosek
(@mnosek)
RE: fixing errors
Got my satin Powder Sheet this week thank you for that suggestion. It is best of the 3 sheets I have
Opublikowany : 09/07/2022 2:20 am
Swiss_Cheese
(@swiss_cheese)
RE: fixing errors
@mnosek
it is the best of the three sheets, but you still need to be aware. it's not perfect and you should make an effort learn, not just assume it's all good. the other sheets are very useful as well.
Regards
Swiss_Cheese
Opublikowany : 09/07/2022 2:35 am
mnosek
(@mnosek)
RE: fixing errors
For now only working with PLA and PETG  so it is nice as i do not need to adjust Z. First layer is same for both
Opublikowany : 09/07/2022 4:27 pm
chick boom
(@chick-boom)
RE: fixing errors
I'm not tracking. You download the STL, load it into Prusaslicer, then adjust any settings, if needed. At no point in the process of slicing and printing an .STL is there any need to deal with an .obj file.
Opublikowany : 13/07/2022 7:06 am
hawai
(@hawai)
RE: fixing errors
Posted by: @chick-boom
Actually there is to a certain degree. When you use the mesh repair option in PS it suggests to save your repaired file as an .obj. This might be where the OP's reference to it came from.
Opublikowany : 13/07/2022 8:24 pm
brucce tran
(@brucce-tran)
RE: fixing errors
i have done z high and let't do other high
Opublikowany : 18/07/2022 7:12 am
Anthony Hawkins
(@anthony-hawkins)
RE: fixing errors
The answer used to be Netfabb but their desktop software is no longer supported, and their web client has been shut down.
Opublikowany : 22/07/2022 8:06 am
Strona 2 / 3
